83 Monte wiring diagram help
6spdg37s
369
259
this might clear that up...
thank you so much ! cause I noticed some had things plugged in some didn't so now this makes more sense... so pretty much I need to check a couple of those connectors.
I found the door lock relay in the passenger kick panel, I'm sure there is a window relay somewhere.
I also would like to find the factory ground points to ensure that they are still intact
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
drogg1 gave you the link to the wiring diagrams and this is one of them....there is no power window relay, it runs off a 30 amp circuit breaker
