Take a look at this, http://www.mmxpress.com/technical/connections.htm
Soldering is the best way to do it.
87GrandPrix said:Ok, Thanks, How would you go about splicing it. Ive done it but never on something like this. Where should I peel back the plastic and should I wrap the whole green wire around it and tape it or should I do a different approach.
custom442 said:87GrandPrix said:Ok, Thanks, How would you go about splicing it. Ive done it but never on something like this. Where should I peel back the plastic and should I wrap the whole green wire around it and tape it or should I do a different approach.
you buy a few splicers at your harware or auto parts store. Make sure you can splice it for a three way, should be about 2$ and it's much easier than soldering. Put the longer dist. tach wire in the outside and your new green tach wire end on the inside and press with a pliers. Do the same for the distr. hot wire with your new tach hot wire. takes 5 seconds to splice, literally
87GrandPrix said:The Tach came with 2 of those splicers, It's all installed and everything, I mounted it really low profile, if you look on a grand prix dash, there is a panel under the steering column with a vent on it, I got a longer screwn and mounted the tach right onto the panel through the screw hole. It works nice, but I couldn't splice the illumination wire into the dimmer one so the illum. is fuzed into the ignition.
custom442 said:87GrandPrix said:The Tach came with 2 of those splicers, It's all installed and everything, I mounted it really low profile, if you look on a grand prix dash, there is a panel under the steering column with a vent on it, I got a longer screwn and mounted the tach right onto the panel through the screw hole. It works nice, but I couldn't splice the illumination wire into the dimmer one so the illum. is fuzed into the ignition.
Cool, so everything works?
87GrandPrix said:Yup I tested it all, the only thing is the tach light stays on as long as the ignition is on.
custom442 said:you buy a few splicers at your harware or auto parts store. Make sure you can splice it for a three way, should be about 2$ and it's much easier than soldering. Put the longer dist. tach wire in the outside and your new green tach wire end on the inside and press with a pliers. Do the same for the distr. hot wire with your new tach hot wire. takes 5 seconds to splice, literally
Future reader here...mr evil said:I know you have this in and working, but I thought I chime in here for benefit of future readers.
With regards to your illumination (white) wire, you should be able to look at your fuse block (under dash, drivers side) and if you read it you should see 1 or 2 spots that have 'ill' or 'illum' printed. the spot may or may not have a fuse or plug already in it. You can use a male flat prong connector (spade? connector) to plug in your white wire, it can piggy back on the exsisting connector.
