So, I looked harder at Evil's fuse block picture and I think that the spot he is using, in reference to my fuse block, is where the red wire connects in between the A/C fuse and the 30watt silver fuse. I am very hesitant to try and mess with this...
The general consensus I'm reading is that the brown wire is the one that I want to hook up my white wire to, in order for the gauge light to turn on only when the headlights are on. My Haynes manual seems to confirm this, as a brown wire appears to eventually trickle down to the instrument cluster.
I can see a brown wire connecting to my headlight switch. If I splice my white wire anywhere along that brown wire, that should do the trick. Am I thinking correctly about this?
