mini starter help
ss-santos
20
does anyone know to hook up a gm mini starter
it only hard to bults u know one that u dont hook anything on cause theure is
one wire there already and then the one for the battery i also have one outlet looking on i tried hooking it up but it
wont even a temp to work.
by the way im hooking up 2 other red wires in the same place where the batter wire goes do thats 3 wires and 4 with the outlet looking thing am i doing something bad ?
should i only connect the battery one and the outlet one and not the two other red ones on the side ?
454cutlass
315
24
mass
i belive the purple wire from the key needs to be pluged in to the starter by using a cheep wire connector
ss-santos
20
right ok so i got 3 wired connected to the opper one u see the positive one that is two wires and turns in to one and then one more red wire. and the perple one u see.
if the perple one is wet it wont work i think its from ail some how it got wet becayse the starter ges out but it doesnt spin the little flywheel from it u know
heres a picsture of mine i probably got it wrong
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
have you considered putting in a remote solenoid, then you won't have the wires sitting near the headers and it's alot easier to hook up one wire to the starter...
othtim
392
16
I wrapped all the wires in one of those fibreglass heat resistant boots from DEI. no problems yet
ss-santos
20
thats sick but i never heard of that wgat ecsactly is it ?
