Hi, my Cutlass Supreme 81' engine bay is getting a clean-up. And there's a lot of un-used wires, especially the ones from the ECU (the car had a 3.8 v6 injection before, now a sbc 350).
The engine-swap was done by the previous owner.
Is the ECU no longer needed? Does it control anything in the dash instruments or something?
I'm also doing the AC delete.
Here is the ECU wires
This one was the only cable from the ECU that was still connected to something after the engineswap
I noticed the plug the green wire was going into, is further connected to the AC. But on the same connector, another wire is going from there across the engine bay and into the wire loom on the other side. What use could that be for?
I don't think its for any use, but I cannot be 100% sure.
