The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
vacuum lines
User avatar
David Williamson
vacuum lines
Postby David Williamson on Mon Aug 08, 2011 8:21 pm
I am having trouble figuring out where this air nose is coming from I found 3 vacuum lines un used that were just sucking in air and I closed them and it actually made the car run a bit better, but the car is still not engaging as good as it should.
I also still hear a air nose from somewhere.
I cannot find anything online about vacuum lines so I thought I would come here for a last resort and I know you all know.
If anyone could help possibly a picture or video of all the vacuum lines and if they should be open or closed up, Thank you all so very much.
User avatar
DoubleV
Re: vacuum lines
Postby DoubleV on Tue Aug 09, 2011 3:48 am
David Williamson wrote:I am having trouble figuring out where this air nose is coming from I found 3 vacuum lines un used that were just sucking in air and I closed them and it actually made the car run a bit better, but the car is still not engaging as good as it should.
Engaging?
Maybe you're just hearing the normal sound of the carb/engine doing their thing.
I cannot find anything online about vacuum lines so I thought I would come here for a last resort and I know you all know. If anyone could help possibly a picture or video of all the vacuum lines and if they should be open or closed up, Thank you all so very much.
It would be way easier for you to post pics of what YOU have and we can tell you what's hooked up correctly and what's not, but for starters, all lines should be closed up and not open.
P.S. All your car problems are due to bad karma from running a Chubby engine in your Olds. :wink:
85 Olds 442
Botched Olds 350 build by the crooks at Rocket Racing. Lunati 207/213 Voodoo cam, 8.1:1 CR ( was supposed to be 8.8:1 ), Stock #7 heads ( was charged for work that was never done and what was done was done wrong ), American Racing headers, Performer RPM intake, Qjet with 1/2" 4 hole spacer, 2.5" Pypes X-pipe system, cowl induction scoop.
Engine never ran the way it was supposed to from day one due to Rocket Racing's negligence. John Stolpa refuses to contact me about it.
User avatar
David Williamson
Re: vacuum lines
Postby David Williamson on Tue Aug 09, 2011 6:37 pm
Like when I hit the gas it doesn't get up as soon as I hit the gas it waits for a second like lags then goes.
I will gladly go take pictures now of all the lines I covered.
The noise could be regular but I don't know I guess I will just not worry about that so much.
Also I know I hated the fact of putting the engine in a olds especially when I wanted to keep it all olds, but it was 200$ and they put it in so as broke as I am that was a deal and I hopped on it.
User avatar
CHRIS.O
Moderator
Re: vacuum lines
Postby CHRIS.O on Tue Aug 09, 2011 8:04 pm
It had a Buick v6 in it so it wasnt even a true olds anyway :mrgreen:
Well your vaccum lines should not be too hard to figure out. Off the top of my head I can list some lines. Your gonna need one on the vaccum advance, pcv, one down to the trans, vaccum modulator I think is what that is called. May cause some problems with shifting if that is not hooked up. You also have one going to the brake power booster. I know not very specific but gives ya an idea of what should have a line running to it. Cannot think of anymore right now, those are just off the top of my head.
When in doubt, tach it out.
User avatar
David Williamson
Re: vacuum lines
Postby David Williamson on Wed Aug 10, 2011 2:18 am
CHRIS.O wrote:It had a Buick v6 in it so it wasnt even a true olds anyway :mrgreen:
Okay thank you so much I will go take pictures first thing tomorrow to give everyone a better knowledge about what I have UN-hosed.
But I will go check the vacuum modulator cause I don't think there is any hose coming from the tip.
Thanks again and I will surely get those pictures, I know they will be a much better help.
User avatar
David Williamson
Re: vacuum lines (picturs)
Postby David Williamson on Thu Aug 11, 2011 9:55 pm
Sorry it took me so long to get these, But here they are.
There the 5 new ones.
http://s1114.photobucket.com/albums/k531/x2DUMBO4x/
User avatar
CHRIS.O
Moderator
Re: vacuum lines
Postby CHRIS.O on Thu Aug 11, 2011 10:05 pm
Any open holes in the intake need to be plugged. There is one 3 port tree that has the bottom port open. You need to put a cap over that or better yet get rid of it altogether and since it looks like it has 2 other hoses that are plugged hooked into it. I looked at some of your other pictures. Did you ever hook the line going from under the front of your carb over to the oil breather on your D side valve cover?
User avatar
David Williamson
Re: vacuum lines
Postby David Williamson on Thu Aug 11, 2011 10:16 pm
CHRIS.O wrote:Any open holes in the intake need to be plugged. There is one 3 port tree that has the bottom port open. You need to put a cap over that or better yet get rid of it altogether and since it looks like it has 2 other hoses that are plugged hooked into it. I looked at some of your other pictures. Did you ever hook the line going from under the front of your carb over to the oil breather on your D side valve cover?
So I should eliminate the tree port in the front all together?
Yeah i finally got the correct hose and plug for it to all fit.
I got the valves and everything for free so I couldn't complain about spending like 10$ on the little hose and plug.
So plug any open on the intake right away?
and possibly get rid of the tree port all together or just plug the bottom one?
User avatar
CHRIS.O
Moderator
Re: vacuum lines
Postby CHRIS.O on Thu Aug 11, 2011 10:18 pm
Well I was gonna tell ya to take that tree out but ya know your luck it would probably break off in the intake haha. So just get some caps for the 3 ports coming out of it. It will look a lot better than bolts in the end of hoses.
User avatar
David Williamson
Re: vacuum lines
Postby David Williamson on Thu Aug 11, 2011 10:22 pm
CHRIS.O wrote:Well I was gonna tell ya to take that tree out but ya know your luck it would probably break off in the intake haha. So just get some caps for the 3 ports coming out of it. It will look a lot better than bolts in the end of hoses.
That's what I was thinking it looks pretty disgusting with the bolts coming from them.
I was wondering if in the pictures you could see the two in the back?
But I should take out all 3 hoses and just plug the tips?
User avatar
CHRIS.O
Moderator
Re: vacuum lines
Postby CHRIS.O on Thu Aug 11, 2011 10:33 pm
If they do not go anywhere then plug them. This is what I can think of needs vacuum. Transmission, brake booster, that breather on the D side VC, vacuum advance on the distributor. Make sure these all have a good line running to them from the manifold. The vacuum advance can be either ported or from the intake. I know some may disagree but I have never noticed a difference running it to the intake or ported port on the carb. Once all those are hooked up, cap every port on the manifold and carb that is left open.
User avatar
David Williamson
Re: vacuum lines
Postby David Williamson on Fri Aug 12, 2011 1:08 am
CHRIS.O wrote:If they do not go anywhere then plug them. This is what I can think of needs vacuum. Transmission, brake booster, that breather on the D side VC, vacuum advance on the distributor. Make sure these all have a good line running to them from the manifold. The vacuum advance can be either ported or from the intake. I know some may disagree but I have never noticed a difference running it to the intake or ported port on the carb. Once all those are hooked up, cap every port on the manifold and carb that is left open.
Okay all will be done hopefully tonight, or tomorrow.
I am not tired at all so maybe I will go out and do them tonight.
Thanks for everything.
I will give an update and some pictures when i plug everything up.
User avatar
David Williamson
Re: vacuum lines (more pictures)
Postby David Williamson on Fri Aug 12, 2011 2:19 am
They all have lines to them other than the transmission.
I took pictures of them all having lines and the trans seems to not have one.
Brake Booster has one, Vacuum advance has one.
The breather on the Dside valvecover, what does it go to, If I got a hose where would it connect to?
But I will plug all the ones properly tomorrow, and take out the ugly screws, lol.
78 salon
Re: vacuum lines
Postby 78 salon on Sun Aug 14, 2011 9:54 am
Since you're probably running a Q-jet, do a double check around the base plate. There's a couple of small vac. ports there in the back. Also, with the car running, spray some starter fluid around. If you have any leaks, the engine will speed up, then idle back down.
User avatar
David Williamson
Re: vacuum lines
Postby David Williamson on Sun Aug 14, 2011 2:41 pm
78 salon wrote:Since you're probably running a Q-jet, do a double check around the base plate. There's a couple of small vac. ports there in the back. Also, with the car running, spray some starter fluid around. If you have any leaks, the engine will speed up, then idle back down.
Okay will do, Thanks for that.
So spray the starter fluid at the bottom or all over?
Return to Oldsmobile Cutlass / 442 / Hurst/Olds
Who is online
Users browsing this forum: No registered users
