The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
Cutlass Supreme budget sleeper build
User avatar
Intragration
G Body Guru
Postby Intragration on Sun Feb 12, 2012 12:09 am
I've wanted to do this build for probably 20 years, a big block sleeper Cutlass. I'm finally just now getting around to it. It's going to be very middle-of-the-road as sleepers go, not the best performing, not entirely grandma's car in appearance, just a nice, plain-Jane coupe with a little something extra. I like that it has the SSIIs and no vinyl top. I have an identical set of 15s that I'm going to run with RWLs, but this will be the extent of the flashiness. Still got the red bench seat interior with column shifter. It was an AC car, but this was already mostly removed, so I've stripped the rest of it. CC and rear defrost were the only other power options, everything else is manual. :)
Getting the car running and drivable on a budget before Winter, and getting some fall cruising in was the goal of the initial phase of the project. I mostly met this goal, except for the budget part ha ha. For right now I'm just catching you guys up to where it's at now. Here's the car as it appeared in the auction listing in September of '11, a mostly stock 3.8 roller that had been off the road for about 10 years:
It's an '83, but it came with '84 grilles, including a spare to fix the broken one.
Mike - 1983 Oldsmobile 455 Cutlass
My build thread http://www.gbodyforum.com/viewtopic.php?f=10&t=35347&hilit=sleeper+build
User avatar
Intragration
G Body Guru
Re: Cutlass Supreme budget sleeper build
Postby Intragration on Sun Feb 12, 2012 12:16 am
Here it is on the way home from Indiana, and stored temporarily outside while I made room for it in my garage.
BillsHoe
Postby BillsHoe on Sun Feb 12, 2012 1:03 am
Looks nice and clean good luck with the build...
1985 Olds 442
User avatar
Intragration
G Body Guru
Postby Intragration on Sun Feb 12, 2012 1:09 am
The very next day my buddy Ryan and I went to pick up the motor, a '70 455. I don't know a whole lot about it, but here's what I do know. It's a '70 block and heads, I was told it only had a couple thousand miles on the rebuild. The guy I got it from had it in an original turbo car, and wanted to restore it back to a turbo, so he just didn't need it. It ran very well, and I got a chance to drive the car it was in. I didn't do any kind of testing on it, but it ran smoothly enough, and the oil was clean enough that it seemed possible. It wasn't very expensive, downright cheap if it was in fact recently rebuilt. It came with an also supposedly-low-mile TH350.
I got it back to the shop and decided to do gaskets, intake, oil pan and valve covers, just to be safe. While I had it apart, I did a little inspection, and I was happy to see that it really did appear to have been a recent rebuild. It's got Keith Black 1631 pistons, a Melling M22F pump, and a new timing chain. All of the rods and caps were marked, and the crank had reference marks for the machining that was done. I was told that it had a "mild cam", I don't know what exactly. I did a VERY unofficial measurement of the wear on an intake valve stem, and the valve that was furthest off the seat appeared to be at almost exactly .500 lift. On the exhaust side, I was able to see what appeared to be hardened seats. I don't know for sure, but I compared with another set of '70 heads via the exhaust port, and mine definitely have a bit of a ridge around the seat that stock ones do not.
It also came with an Edelbrock Performer and an Edelbrock 600 CFM carb. I have since picked up a 7040251 QJet that I'm going to have rebuilt. Here's the motor freshly out of the turbo car, before clean-up, a couple inside pictures, and then cleaned up and ready for install.
User avatar
black86442
Postby black86442 on Sun Feb 12, 2012 1:24 am
Looks good all cleaned up and painted.
-86 442 had sbc when i got it.
Sbc 350 9.5:1 ported l98 steel heads 270/278 comp extream 4x4 cam orignal torker intake 750 holly
hooker long tube headers true 2.5" duals with thrush welded mufflers
700-r4 with shift kit
8.5 373 gears
User avatar
Intragration
G Body Guru
Postby Intragration on Sun Feb 12, 2012 1:37 am
After getting the motor cleaned up and resealed, I started working on the car. The first step was to get the old 3.8 frame mounts out. This is not a simple thing to do, it just requires the right combination of sockets, extensions and wrenches and a lot of patience. Once these were out, I cleaned up the engine compartment real good, degreased it and painted with POR15. I didn't worry too much about the suspension components, I can work on these from the wheel well area when I clean those up. While the motor was out, I figured this was the best time to clean up and paint the core support too. I did all the less visible areas with POR15, and the more visible areas I prepped better, primed and sanded several times, and painted with Krylon semi-gloss.
Next you can see the Olds V8 frame mounts in place and the fuel line extension, bringing it over to the passenger side. I'll eventually do a new full-length V8 fuel line, but I've just done 3 full brake line replacements in the last couple years, I couldn't bring myself to do this just yet. To figure out just where the fuel line needed to hook up to the fuel pump, I made a jig out of a coat hanger that measured the exact relationship between the motor mount and the fuel pump on the motor. Then, on the car, I just put the motor mount side by the frame mount, and it indicated exactly where the fuel line had to terminate.
Next is hood off, ready to go, with headers hung in place.
User avatar
zuma83
G Body Guru
Postby zuma83 on Sun Feb 12, 2012 1:38 am
Nicee
User avatar
Intragration
G Body Guru
Postby Intragration on Sun Feb 12, 2012 1:48 am
Getting the motor in was pretty easy. There was a slight interference somewhere on the passenger side that I couldn't quite track down, but moving and rocking it a little overcame that and then it settled right down. Make sure if you use the hand-crank leveler like I have, that you have the handle to the FRONT of the car, not towards the cowl like I have it.
User avatar
Intragration
G Body Guru
Postby Intragration on Sun Feb 12, 2012 2:11 am
The computer harness comes out to the engine compartment through the firewall on the passenger side. There was nothing that I was going to need from that harness, so I decided to remove it. The easiest way I found to do this was to cut all the wires as close as possible to the firewall on the engine side. Then, from the passenger compartment, I just pulled on the harness and it pulled right through the grommet. I sealed the grommet with a plug and some silicone, in case someone ever wants to return the car to a 3.8 CCC. :lol:
Before installing the motor, I improved the timing markings on the balancer, so I can easily check the timing without using a dial-back timing light. Just used the existing timing marks as a reference, and added marks to the balancer up to 45 degrees. The small hash marks are 5 degrees and the big ones are 15 degrees.
Before doing the install, I was convinced that the battery cable running to the starter was going to be a big problem due to it's proximity to the Hooker 3203 headers. I made an insulator for all the wires running along the side of the block to the starter out of two spark plug wire insulators to shield them from the heat. As it turns out, there is a great chasm of space between the block and the headers. Maybe this is unique to the 3203s? Maybe others had problems with SBO headers and clearance? I don't know, but on a BBO G-body with Hooker 3203 headers, there is zero problem. Even the starter is clear of the headers, and could easily be replaced without touching the headers.
Of course the transmission crossmember is a problem...
User avatar
Intragration
G Body Guru
Postby Intragration on Sun Feb 12, 2012 2:27 am
I resolved this by modifying the stock crossmember. I could have purchased one of the aftermarket ones, but having just purchased a car, a motor, and G-body BBO headers, I decided to go the budget route this time. I marked the factory crossmember, cut out a healthy chunk of metal, and fabbed up some sheet metal to wall in the notch and some c-channel stock to reinforce the top. With the help of my friend Kevin's welder and a crash course in MIG welding, I had the whole thing done in a couple hours. I'm very happy with how it turned out. It's got plenty of clearance, it seems plenty strong, and it turned out better than I expected.
85GPLef41
Postby 85GPLef41 on Sun Feb 12, 2012 2:38 am
Looking good!! Keep up the good work! more pics!! 8)
1985 Grand Prix L.E."Pro-touring" car:
5.7 LS1 99 Formula TA , 1998 Camaro T56 six speed, 8.5 Buick 3:42 GN posi rear, 78 LeMans Aluminum core support,front 13in early C6 brakes & rear C5 calipers with 12in LS rotors, Hotchkis coils and rear control arms etc etc...ALL IN PROGRESS.
my pics:
http://s387.photobucket.com/albums/oo316/netochingon1/
User avatar
Intragration
G Body Guru
Postby Intragration on Sun Feb 12, 2012 2:47 am
A little bit of wiring, a little bit of plumbing, made a list and checked it twice, and that was about it for phase one of the project. It started up on the very first try, which was unbelievable because I had installed a new HEI while the motor was out of the car, and it was drivable almost right away, after a good deal of carefully moving it forward and backward a few inches at a time and testing the brakes. I took my time putting it together, but still got it done in plenty of time to enjoy it a little bit before winter. The car came home on September 20th, and the picture at the gas station was the first drive, on October 20th. Here's one at it's first show, not much to show, I hadn't even detailed it yet, but still fun.
User avatar
Intragration
G Body Guru
Postby Intragration on Sun Feb 12, 2012 3:11 am
Here's one of the quick exhaust system I threw on, just to have something. The interior is complete except there's no carpet, and with open headers, it was like the end of the world inside. Finally, a few of Fall cruising, and the last one as it sits now, waiting for the 8.5 and the '12 season. :D
If you've got any questions or there are any pictures you want to see, let me know. I have lots more, this was just sort of my summary of the build up to this point.
User avatar
dogshit
Postby dogshit on Sun Feb 12, 2012 4:10 am
All them great pics you need to put them in your photo album so they can be seen anytime instead of just on this thread. Great job btw.
In the muscle car era if it had a small block it was your moms car. When you turn your car on does she return the favor? Life's short enjoy your ride. Hybrid burns gas & rubber. Check out my photo album.
87 Olds 442, Blue on Metalic Silver with 275/60/15 drag radials on 15x8 442 wheels, 10-1 509ci Cadillac, 800cfm Q-jet, Performer intake, Street ported heads, 230@50 518 lift cam, Headers, Built 200-4R, 2800 stall lock-up converter, Electric fans & in-tank fuel pump, Factory AC, All factory guages work including tach & oil temp with the 509, Functional Hurst hood & rear spoiler, 36mm hollow sway bar, 3.42 posi 8.5, 17.0 mpg hwy, sold :(
87 Buick Grand National, Tuxedo Black w Chrome 275/50 drag radials on 15x8 GN wheels, 231 Buick V6, TE-60 turbo, Stretch intercooler, 42.5lb injectors, 3" downpipe, 3000 stall lock-up converter, Meth/water injection, 3.42 posi 8.5, 22 mpg hwy, original owner ~ Goal for both cars 11.8 ETs / 115 mph in the quarter reliably on pump gas
User avatar
trocutlass63
Postby trocutlass63 on Sun Feb 12, 2012 5:28 am
Absolutely beautiful car, it looks similar to mine only much cleaner. That 455 has got to be just a ton of fun in that car :D
'85 Oldsmobile Cutlass Salon-Olds 307, TH350, 7.5" 10 bolt
Mostly stock (for now)
Next
Return to Oldsmobile Cutlass / 442 / Hurst/Olds
Who is online
Users browsing this forum: No registered users
