Pics of your Lowered Cutlass
V6UnderPressure
202
8
New Lenox, IL
Would like to start a thread with photos of lowered Cutlasses. I'd like to know how much drop, what springs/shocks you are using, and tire size to see what fits. I'm trying to get an idea if I wanna go 1 or 2 inch drop. Thanks all!
V6UnderPressure
202
8
New Lenox, IL
moose said:
If you decide to drop yours an inch, I have a full set of used Belltech shocks that lower the vehicle 1" by themselves. They've got low miles on them, about six months worth of driving. I don't have any pictures of my car with them installed, but I now have about a 2" drop and will get some pictures and product details later today.
Pics would be great. Thanks. I actually have a hotchkis kit, and I am debating whether to go with a 2" drop. I'd hate to button it up only to decide otherwise.
1983regal
263
St. Louis MO.
Shocks can not lower a vehicle unless they are coilover shocks with the spring assembly attached. If you are trying to sell those please change the description so that it does not say the shocks will lower your car. i think this is a great thread though, we should have one for each G body so people can see how they look lowered. Mine has stock sagging springs and I love the way it sits, but is a regal so I will not post a pic in your thread.
moose
188
16
ICT, KS
I've got the steering wheel out and am in the process of filling in all the cracks so I couldn't pull it out for a good overall shot. I'm using SPC springs and Bilstien shocks all around. Tire size is 235/60R15 front and back. I had to put a 1/4" spacer on the front to keep the tire from rubbing on the frame during tight turns. As bad as the pictures are I hope this helps some.
Front
Rear
moose
188
16
ICT, KS
I understand your point of view and admit that I don't know a lot about suspension technicalities. However, I can say that after installing JUST these shocks my ride height was a noticeably lower, just a little. I had my entire suspension upgraded with the old SC&C stage 2 and got the look I wanted. I just recently replaced the Belltechs with Bilsteins and after driving it around for a week the wheel well clearance still looks more than it did. Maybe it'll settle a little more with time. Also, Belltech and Summit both state that these shocks will lower the ride heighth 1" and Mark at SC&C seems to confirm this when he indirectly told me in a ten minute explination that shocks can affect ride height.
However, I could be wrong. Either way, I'm not try to spread misinformation, I'm posting based on my personal observations. Also, I'll remove the bit about my shocks as to not cause a ruckus.
Dennyboy
387
16
Minnesota
looking forward to seeing more in this thread ide like to lower the front of mine a little.
mr evil
Moderator
Moderator
Aug 4, 2009
857
544
Sooke, BC, Canada
Moose, what is the backspace on the rims you are using? Were you getting any bottoming out on bumps or just the rubbing?
moose
188
16
ICT, KS
Mr.Evil, I do not know the backspacing. They're old Cragars that came with a Monte I bought years ago. They fit the Monte so I threw em on the Cutlass without much thought. Just rubbing issues, never bottomed out. Since I put on the Bilstiens I can now fit my whole fist in between the tire and wheel well. My tire height is 26.1" and Mark at SC&C said he doesn't recomend anything over 27" with his suspension setups.
mr evil
Moderator
Moderator
Aug 4, 2009
857
544
Sooke, BC, Canada
Ok, thanks, I'm running the same size wheel with a 2" drop spring, but I haven't got it all together yet to see what effect it will have.
