The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
Bucket Seat Question G BODY
442kid
Postby 442kid on Thu Feb 21, 2013 12:59 pm
Hi Guys,
I have a couple of questions regarding factory bucket seats in 1980's G BODY (Cutlass specifically but they should be the same). I know you install bucket seats in a car with factory 60/40 bench. So are all the brackets the exact same on bucket seat and a 60/40 front bench? Can you swap the ones from a bench to the bucket seat if needed? I have a pair of bucket seats I bought with no tracks and I have 4 tracks from I believe a 60/40 front bench. Wondering if they will work 100%. Any body have a picture of the bucket seat mounts from the bottom side I can compare?
Second question also regarding bucket seats but this I am referring to a drivers ower bucket seat. The seat in car is suppose to work but I was told the fuse kept blowing and it was pulled? I don't see anywhere for the fuse for a pwr seat...Is there a replacement fuse location in the box for the optional pwr front seat (1985 salon)? Wondering if the seat does work like it is suppose to or if I was fed a line :?
Any help much appriecated. Darryl
User avatar
Lowproelco
G Body Guru
Re: Bucket Seat Question G BODY
Postby Lowproelco on Thu Feb 21, 2013 2:01 pm
yes 60/40 tracks will work for you i did the samethang and thang.. but i cannot answer the second question..
442kid
Postby 442kid on Thu Feb 21, 2013 2:39 pm
Thanks for the feedback...if anybody has picture showing the feet on a bucket seat from bottom etc I don't know if I have a full correct set or some duplicates as they were in storage.
Huroncountycutty
Postby Huroncountycutty on Fri Mar 08, 2013 3:31 am
If it was blowing fuses,I would think there would be a short in the seat motor, switch, or in the harness that went to them? I would run a new power with an inline fuse under the seat or something, just to be sure,
User avatar
jmt455
G Body Guru
Postby jmt455 on Fri Mar 08, 2013 9:57 pm
The power seat circuit does not use a fuse; current protection is provided by a 30A circuit breaker on the fuse block.
The breaker is located on the right side of the fuse block, 2 rows above the turn flasher and next to the 10A radio fuse.
The power feed should be plugged into the red "BAT" terminal just below the breaker.
1983 Bonneville G wagon
2008 Pontiac G8
User avatar
Clutch_Grabwell
G Body Guru
Postby Clutch_Grabwell on Fri Mar 08, 2013 10:53 pm
60/40 tracks don't always work with bucket seats. Split bench seat bottoms come in two different mounting bolt widths. Measure across where the tracks bolt to the seat, buckets will measure 13.5", split bench will sometimes measure 14.5" and then the track feet will miss the floor studs. BTDT.
1986 MCSS, T-tops, TPI 350, T56, 8.5" 3.42:1 Posi, cruise, A/C, ZQ8 brakes
All power: Windows, locks, mirrors, 8-way GTO seats
Concert Sound II, seven speakers, two amps
As seen in Hemmings Muscle Machines Aug. 2010
http://www.hemmings.com/mus/stories/2010/08/01/hmn_feature6.html
442kid
Postby 442kid on Sat Mar 09, 2013 10:21 am
Thanks guys got the pwr seat working it was unplugged at the fuse block and it seems to work fine. Still have not tackled the bucket seat track swap but now that is warming up outside I will be more motivated. Thx Darryl
Return to Oldsmobile Cutlass / 442 / Hurst/Olds
Who is online
Users browsing this forum: MeanBuicks
