seawolf18 said:The first place to start is with the codes. Pull the codes and post them. Why was the carb replaced? I'm guessing the car went over 20 mph before the carb replacement? Did you make sure the tv cable was put back on properly?
-83MONTESS- said:Is it not shifting? What happens when it hits 20mph?
Jeezycol said:I just replaced the carb with a brand new stock carb
DoubleV said:Jeezycol said:I just replaced the carb with a brand new stock carb
Really? A BRAND NEW stock carb? Where did you get that?
Now if you replaced your stock card with a REBUILT stock carb, then I would say it is very possible this rebuilt carb was rebuilt incorrectly. Where did you get it?
Either way, you need to provide us with more details on your current setup and tune. Some pics may help too.
