Tire size
gharris79
Sep 21, 2011
87
38
Miramichi NB Canada
I'm looking for opinions on tire sizes for my 87 Cutalss. I'm currently thinking about going from 215/70/14 to 245/60/15 both on Cutlass wheels. I want to fill my wheel wells more and have a wider stance with the 60 series tire on 15x7 wheels. Do you think this will look ok? Anyone have a picture of their car with this tire wheel combo? Here is a pic of my car with the 215/70/14 on it.
pacman350
Jun 5, 2012
88
6
monticello, Ga
Well a buddy had a 87 mc ss with 235 60 15 up front and 245 60 15 out back and it gave it a real mean stance. Im gonna go wirh 235 60 15 all the way around right now i have 215 70 14 and to me there just to small and to narrow. And 245 60 15 on the front might scrub because its a pretty wide tire
gharris79
Sep 21, 2011
87
38
Miramichi NB Canada
I've looked at a few last summer at a car show that had 245/60/14 on them. They had factory 14x6 Olds wheels on them. The wheels I'm going with are 15x7 wheels off a 442 so I'm sure they will be wider. I'm going to lower the car as we'll so I should take that into consideration.
N3M3S1S
Mar 24, 2013
98
103
33
Wilmington, DE
My plan is to go 255/70/15 in the rear.
DoubleV
2,154
406
83
Medina Ohio
Keep in mind when choosing a tire size that some sizes aren't available for certain brands. So say you wanted a larger sized tire in the rear and you wanted to go with ( for example ) the Firestone Indy 500 tires. That model tire may be available in the size you want for the rear but not in the size you want in the front ( or vice versa ).
Also keep in mind your speedo. IMO, it's best to go with a tire size that was available from the factory. That way you can easily find out what speedo gear you need to have an accurate speedo. Because of this, I recomend 235/60/15's. That is the same tire height as the 215/65/15's which were stock on 80's 442's/H/O's, so it's easy to get the proper speedo gear.
gharris79
Sep 21, 2011
87
38
Miramichi NB Canada
Thanks for the input. I want to run BF Goodrich TA's
N3M3S1S
Mar 24, 2013
98
103
33
Wilmington, DE
Around here Pepboys has Futura tires in the size I'm looking for at about 100 bucks a pop. I've had good luck with their brand in the past and it even has the raised white letters. As far as the speedo is concerned.. Mine has been off since I bought it so I'm no so much worried about it. It works when it wants to. Lol.
