88 cutlass overheating after water pump swap
chitownserb
9
Hello, I had recently replaced the water pump on my cutlass with a new one. I noticed that the engine starts to overheat even if its idling. The coolant reservoir is constantly filling and draining it self. Does any one know what this can be?
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
Sounds like it could be the wrong pump and one for a serpentine set up which runs the opposite direction. I had a similar problem with mine that turned out to be the problem. Right number on the box but wrong pump
chitownserb
9
The new pump is the right one. I got it from autozone and it matched up exactly with the stock pump. Is it possible that i didnt fill it up right or something. Air in the system maybe?
crucial118
1,055
51
48
MARYLAND, DMV
There's the problem, you bought it from Autozone. :D What Pontiacgp is saying is it may be the correct part#, but the impeller inside might be one for a reverse rotation pump for a serpentine setup. They look identical, just 1 pumps in reverse and 1 pumps in clockwise rotation.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
The only difference between the two pumps is the impeller. When you remove the rad cap can you see the coolant flowing?
DoubleV
2,154
406
83
Medina Ohio
Does Olds even have a reverse flow waterpump?
FE3X CLONE
2,714
47
48
Ohio
Yes. I have one on my 455 with the serpentine conversion. It's a stock replacement for the 4.3l v6 diesel engine.
However that pump does look different from the standard pump.
Before tearing everything back apart I would check that there isn't any trapped air in the system. Did you "burp" it when putting in new coolant? What does your coolant level look like?
I always fill the radiator up then start the engine and let it warm up until the thermostat opens. You'll typically see a lot of big fluctuations in coolant level as the trapped air is released. As the level goes down just keep adding a little coolant mix until everything finally settles down.
Then replace the radiator cap and put some coolant in the overflow and you should be set.
If that doesn't work then I would look at the possibility that the pump you have had the wrong impeller installed.
tetomas
156
east central georiga
Was it running hot before you put on the water pump? Could be an entirely different issue, like a thermostat, or a plugged up radiator.
88hurstolds
1,747
658
Most likely you have air in the system.
Although I wouldn't be surprised with the *ss hats at those auto parts stores and the sh*t parts they have to peddle... every time I walk into one I basically commandeer their computer.
