Best transmission for a Olds 455 engine
tlonz442
n00b
Mar 28, 2014
2
Hello users, I'm currently wondering if u can't find a turbo 400 transmission , so would a turbo 350 transmission hold up behind a Olds 455 engine or could better parts be put inside the 350 to make it stronger? (88 cutlass supreme)
lilbowtie
3,460
3,965
Canton Mi
T-400's are still plentiful as are the 350's. The 400 is my personal choice but 350's can be modified to handle 800 bhp. Ron Sessions has a books on how to build and modify the
t-350 and the t-400 transmissions - great books and can get an amateur through a rebuild.
Oct 14, 2008
8,822
7,770
Melville,Saskatchewan
How stock is the 455? If it is mild, the stock 2004R will live with a few key hard parts like the stator and forward drum. Add a 10 vane pump, big shift kit with bigger boost valves, billet servo and quality convertor, clutch,bands and your there. The TH350 is no prize stock, I have seen two smoked by a stock 75 and 76 Olds 350. We are talking 165hp/265 tq, pretty poor that they died. I know someone who put stock TH350's behind a stock 70's 454 in a 79 Camaro swap. He blew 3 or 4 in short order. He added a shift kit to the last one and sold the car. The 4L80E is the best of both worlds but needs an adapter and controller or manual valve body. Be aware that you will eventually explode your spider gears in the 7.5" rear too.
  • Creative
jetsetw31
678
67
Petersburg, VA
