Rally gage pack restoration
84cutspreme
1,144
151
How do I disconnect speedo cable from the back of gage to get whole gage pack out?
grandamman
809
415
up in the hills
If you have cruise control, the easiest way is to disconnect the speedo cable from the transducer located on the inner fender wheel well.
The gauges will pull out a lot farther. You'll see a small clip on the end of the cable at the back of the gauges. Press that in and the cable should release.
If you don't have cruise, you may be able to reach in far enough to reach the clip.
84cutspreme
1,144
151
Thanks for the response, i just disconnected at trans n it gave me all the room in the world...now trying to figure out how to release connectors that headlight n dimmer go into. They seam to have dual clips into dash
