help finding hold down bolt on distrubitor 307HO
sonseeker
25
Looked and looked and can't seem t find it. What is the optimum setting for timing? Thanks in advance
FE3X CLONE
2,714
47
48
Ohio
Hold down bolt is on the drivers side of the distributor where the distributor meets the block. Takes a 9/16" socket I believe.
Optimum setting should be listed on the radiator plastic shroud. I know for the standard roller 307's is was 20* initial @ 1100RPM.
sonseeker
25
Thanks for the help,i found it. I believe there is something you have to unhook to set the timing?
FE3X CLONE
2,714
47
48
Ohio
I'm assuming you have an all stock 307 that still has all of the CCC electronic controls?
If so then before setting the timing you are supposed to jumper the A and B terminals on the ALDL under the dash using a paper clip. This disables any timing advance by the computer. Then you can adjust the timing like any other vehicle.
sonseeker
25
Thanks again for your vast knowledge.Yes it is still stock with the PIA Quadrajunk carb(I have 2 of them both rebuilt, that will be for sale) that was rebuilt by an "EXPERT?" if this doesn't fix the problem Eldebrock carb here I come. I have held off on doing this for years but nearing my wits end. Thanks again
DoubleV
2,156
406
83
Medina Ohio
A Qjet is not junk. Maybe you just don't have your Qjet tuned right. They can be tricky. If you ditch it for an Edelbrock ( which btw IS an inferior carb ) you will no longer be able to run on the computer anymore. This means you need a new distributor.
Who was this 'expert' that rebuilt your carb?
88hurstolds
1,747
650
Most likely the problem is not the carb if you had issues with two rebuilt units.
I had issues with my '83 H/O when I bought it, it ran rough, wouldn't idle and would die at random not to mention it would diesel upon shutoff.
I replaced the EGR and solenoid and it fixed the stalling issue some but not completely.
Then I noticed the factory block off plate was missing from the Air Bleed Valve and some idiot decided to "turn some screws" instead of fixing the problem with the EGR first which is a major no no with factory CCC Q-jets.
Turned out the Air Bleed Valve wasn't adjusted correctly, all I did was adjust it back to factory and all my problems went away, it was crazy the significance of this adjustment played in a number of issues.
It runs perfect now.
EGR can be a major factor, especially the solenoid.
Don't forget about the MAP sensor as well and don't use any aftermarket O2 sensors, they are junk.
Find an AC Delco one.
Always address the typical tune-up ware related parts first before turning screws on a carb or thinking the carb is the issue.
