I swapped out the 307 in my 86 442 for a 71 350. im using the power steering pump from the 307 and had some trouble installing it on the 350. The bracket wouldnt line up , had to use a couple washers. But got it on. the pully when it turns its wobbly and hits the bracket . Is there a o ring on that pully or should i replace the pump ....
