Ls swap
83olds5.3
n00b
Oct 21, 2014
George Town, Cayman Islands
Whats up guys new to the group,but i have a 2004 5.3 to put in my 83 cutlass and im wondering where i need to start as motor mounts,oil pan rumors,and i also want to keep it fuel injected. Someone help me out because i really want this done right and to not be really pricey
L92 OLDS
2,872
3,050
West Michigan
BRP offers solutions they may not be the most cost effective. Last time I checked, they were pricey. Others are using 1" offset mounts like the dirty dingo brand which are adjustable. You will need a new oil pan (Hummer oil pan or Holley muscle car pan). Another alternative which requires fabrication skills and a good welder is to modify the cross member. LS1Tech.com is a good resource. Spend some time there reading and do your homework before buying anything.
jacobdavis1979
700
14
If i may chime in im in the middle of ls swap myself. Simple 1" setback plates used with clamshells. I skimmed your post so i didnt see what transmission your using but a step adapter will adapt a th350 or 700r4 to bolt up to the 5.3 along with the hummer pan the holley pan or the ctsv pan using these parts that 5.3 should drop in like a small block chevy
DoubleV
2,154
406
83
Medina Ohio
Hasn't this topic already been discusses ad nauseum?
