403 olds in a 1981 cutlass
1981ctls
7
Awhile ago i was looking at putting a 455 in my car but found a 403 out of a 79 trans am and am wondering if it will involve the same amount of work as the 455 would so any info would be good thanks.
rccktmn2
196
Paulding Ohio
The 403 would be allot less work than the 455. The 403 is the same physical size as a 307 so you can use the same motor mounts, all brackets and accessories will bolt up with no modification. You can use the same exhaust that came off the 307 or sbo headers are available for that body style just depends on how much you want to spend. Good Luck!
dan2286
2,233
4
Cleveland, Ohio
Should be less work. The 403 is externally identical to the 307 so it's just a matter of swapping some parts over and dropping it in. This is all assuming you have a 307.
1981ctls
7
i supose i should have mentioned that the car currently has a chev 350 and th350 trans will my current trans bolt up to the 403 or will i have to go to a th400 with 2004r trans member?
dan2286
2,233
4
Cleveland, Ohio
This is for a 3.8 to Olds swap, but most of the info is the same. http://www.robertpowersmotorsports.com/G-bodyV6-V8.html
Do you know what engine was originally in the car? You will need a different trans but it does not have to be a 400. It just needs to have the BOP bolt pattern. That could be a 350, 400, 200-4R, or 200.
1981ctls
7
well seeing as i live in canada i would asume that it came with a chevy 305 as did my 84 cutlass so if i did find a th350 with the BOP bolt patern would i need to change mounts from the chevy th350 mounts
dan2286
2,233
4
Cleveland, Ohio
No, they should be the same.
Blake442
6,864
1,997
Minneapolis
Why do you say that? :?
A 455 requires no more work to install than a 403 would.
They're pretty much the same thing, with the exception of the 455 being a tad wider/taller due to the added deck height.
rccktmn2
196
Paulding Ohio
IMO it would be easier not neccessarily less work. Considering the 403 is the same dimensions as the 307 everything will bolt up without any modifications, the 455 would require 455 brackets and then you would have to move some accessories around, that is if your keeping the accessories. Then the exhaust from the 307 would bolt up to the 403 with no problems, the 455 would require either the exhaust manifolds from a 455 or headers which are more expensive in a g body than regular sbo headers for a g body, then you have single or dual exhaust, 307 will bolt right up, 455 would require either custom exhaust work or a dual hump crossmember and dual exhaust. Then you run into the right intake to put on, if you do a tall aftermarket alluminum you have to get a different hood, if you do a short aluminum intake you can do a stock hood, or you could go factory. I guess I should have said more things to consider not neccessarily more work, installing an engine is installing an engine, there all about the same amount of work.
