GBodyForum Supporting Vendor
Floor Shifter
Articles about swapping engines and anything related, mounts, exhaust considerations etc.
joye227
Floor Shifter
Postby joye227 on Thu Jan 07, 2010 11:06 am
I got an 85 cutlass salon with a factory floor shifter and console. I'm switch to a chevy 350/350 combo. What do I have to do to get the factory floor shift to operate correctly with the th350 tranny? Does anybody have a part number to the correct cable and how it should be correctly installed? Thanx
1985 Cutlass Salon
BrownGP83
G Body Guru
Re: Floor Shifter
Postby BrownGP83 on Thu Jan 07, 2010 11:08 am
What trans did the car originaly have?
1983 Grand Prix Dark Brown exterior/bucket interior 383 Stroker Dart Iron Eagle heads 200-4r 3.73 gears Pypes 3 inch full duals with x-pipe MCSS tailpipes
User avatar
Oldsmoletick
Re: Floor Shifter
Postby Oldsmoletick on Thu Jan 07, 2010 11:15 am
If it has the 200 metric three speed, no mods at all.
    81 Malibu classic 4dr (the Oldsmoletick)
    88 Jeep Cherokee 4.0 Q-jet and HEI'd
    81 AMC Eagle SX/4 (Girly's)
    84 AMC Eagle 4dr sedan (Q-jet and HEI'd)
    AMC Eagle Evolution
    http://forums.amcevolution.com/
joye227
Re: Floor Shifter
Postby joye227 on Thu Jan 07, 2010 12:46 pm
I'm sorry, I forgot to mention the car originally had a 200r4 overdrive tranny. And my console gear shift indicator says P,R,N,D,2,1. I hope this will help. How is the cable supposed to be routed?
1985 Cutlass Salon
joye227
Re: Floor Shifter
Postby joye227 on Thu Jan 07, 2010 2:50 pm
Anyone??
1985 Cutlass Salon
User avatar
beermonkey9417
Re: Floor Shifter
Postby beermonkey9417 on Thu Jan 07, 2010 5:11 pm
to do the th350 swap yuoll need a 350 type shifter. you can get aftermarket ones thatll fit under the stock console. and you can get a sweet handel too!
"Gimmie a pickle jar, I'll open that bitch up like a Motherfucker!"
Save Water, Drink Beer! Save A Tree, Eat A Beaver!
-'78 el camino, 307sbc, 14014416 heads, 1.6 roller tip rockers, holley 600 cfm carb, monte carlo interior, 200-4R, rockford 4.11 posi PO-MutherF#$kin-S viewtopic.php?f=7&t=8386
-'94 saturn sl1, 1.9l tbi, 85hp, sony explod headunit, 1200w sony explod amp, 2.4 farad cap, no muffler, jvc 3-way 6 1/2" all around, kicker 12" twin voice coil sub, 15" x 8" chrome rims. - R.I.P.
-'99 infinity I30 3.0 V6 on 17inch rims, 5 speed, stock so far...
-'07 47cc 2 stroke cag daytona, ported carb and #72 jet, stage 2 carbon fiber reed, race tuned exhaust, shwinn speedo, toyota badge, meat hook pegs, street fighter.
http://www.youtube.com/watch?v=efzbqvwBF9E
gpguy
G Body Guru
Re: Floor Shifter
Postby gpguy on Thu Jan 07, 2010 5:55 pm
If its a factory 3 speed shifter should work with any 3speed trans
User avatar
Doober
Re: Floor Shifter
Postby Doober on Thu Jan 07, 2010 6:13 pm
I don't know how interchangability is far as Cutlass consoles, but you may be able to put a stock 3-speed shifter from an earlier year in... the detents for the 2004R and TH350 will likely not match up if it had a PRND21 setup.
-Darren-
'81 Malibu, Vortec'd 350, 4-speed Saginaw, 2.29s. Rusty.
'78 Malibu, de-framed, getting the drivetrain/suspension from the '81.
'92 Sierra, Vortec/TBI 383, 700R4, 3.08s
'87 Fiero GT, 2.8/5-speed
Looking to convert to a manual trans? Click here.
3XBrownCutty wrote:...ill check my nuts...
joye227
Re: Floor Shifter
Postby joye227 on Thu Jan 07, 2010 10:45 pm
I figured if I brought a shifter cable for an earlier year cutlass with a th350 and floor shifter that It would work since I have the right shifter cable.
1985 Cutlass Salon
User avatar
Minion1186
Re: Floor Shifter
Postby Minion1186 on Thu Jan 07, 2010 11:24 pm
I suppose you could use the stock on with th350 linkage,just it wont shift all the way back to first,so the sequence for shifting from the 2004r to th350 is that 1st gear on the indicator is nothing,2nd is first,drive is 3rd and overdrive is 3rd.
Next
Return to Engine / Swaps etc.
Who is online
Users browsing this forum: No registered users
