The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
GBodyForum Supporting Vendor
193 heads on a Carbureted Chevy 350
Articles about swapping engines and anything related, mounts, exhaust considerations etc.
User avatar
Coriolanus
n00b
Postby Coriolanus on Fri Oct 14, 2011 8:51 am
Anyone ever use 193 heads on a carbureted Chevy 350? I'm hearing the flow of the 193 heads is poor and they should not be taken over 5000 rpm.
13bravo
Re: 193 heads on a Carbureted Chevy 350
Postby 13bravo on Fri Oct 14, 2011 11:37 am
I don't remember, are these the Swirl Port Heads? If so they are a bottom end truck head, and I've seen many of them cracked, unless they are the heavy duty truck head with the 3/8 exhaust valves and hardened exhaust seats installed from the factory. Those were less likely to crack but flow even less due to the 3/8 exhaust valves.
If your just looking to build a low end daily driver they should work fine.
No car yet, but I'm working on finding a Malibu Wagon, well lets just say trying to find a G-Body wagon.
User avatar
Coriolanus
n00b
Postby Coriolanus on Fri Oct 14, 2011 2:16 pm
I'm not looking to race or anything like that. I would like to build a car for going to work and cruising. My engine has an 880 casting block number and the 193 heads. With the quadrajet, I should get good fuel economy.
User avatar
bigdan
G Body Guru
Postby bigdan on Sat Oct 15, 2011 7:38 am
if all you want is reliabilty and economy its alright keep the 193 ...
ProPerformance: engine rebuild & mods at honest reasonnable prices ....
1984 cutlass supreme :
350 LT1 2nd gen :
comp cam roller :CC503 / 1.6 roller rockers
gmpp intake / modded Q-jet,
competition prepped 700R4 / 3200 9.5" stall T/C
ford 9" diff with 3:25, 3:55, 3:89, 4:10 gear choice ....
camaro 1LE front brakes
11" rear disc brakes
KYB gas-a-just schocks
bell tech coil springs lowered 1.5"
tubular front A arms
ajustable links rear suspension
User avatar
Coriolanus
n00b
Postby Coriolanus on Sat Oct 15, 2011 11:35 pm
Thanks, I will. I would hate to have to remove the 191 heads on the other block. I hear they crack when removed.
Return to Engine / Swaps etc.
Who is online
Users browsing this forum: FE3X CLONE, olds307 and 403, Plain Jane
