What all is needed? I understand the crossmember and driveshaft depend on what vehicle, but other than that what can you still use? I've got a shift cable from a 2004r car, and I know the shifter bolts into the same exact spot. What about trans lines? Also I see places offering the switch for the TC lockup. I bought a set of 3.23 gears to put in my TH350 car with a 3.73 rear, just to keep it alot more streetable until I can save up for an overdrive swap.
