The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
Proper fluid for 700r4
Stuff like brakes, frame, springs/shocks, tranny's, etc. etc.
User avatar
patmckinneyracing
Postby patmckinneyracing on Tue Jan 04, 2011 1:03 pm
What is the proper type of fluid for the 700r4 between Dexmerc III and Dexmerc VI? Autozone told me that Dexmerc VI is the proper fluid, not that I trust Autozone guys too much. But after reading some posts on diesel and other forums, a lot of people are running Dexmerc III. So what is the proper fluid to be using in the 700r4?
Since Dexmerc VI is a synthetic, it kinda makes sense in my mind since the thinner synthetic fluid would reach the overdrive clutch packs better than regular transmission fluid.
User avatar
Oldsmoletick
Re: Proper fluid for 700r4
Postby Oldsmoletick on Tue Jan 04, 2011 1:14 pm
According to GM dexron VI is backwards compatable to older vehicles that used dexron III and dexron II. I still run dex III in my car (th350), but like dex II which is what these cars came with I believe, dexron III is slowly being phased out. I honestly would stay with dexron III, but that's just my opinion.
*However, dexron VI is NOT compatable with power steering or manual transmissions though.....So it does lack something?
    81 Malibu classic 4dr (the Oldsmoletick)
    88 Jeep Cherokee 4.0 Q-jet and HEI'd
    81 AMC Eagle SX/4 (Girly's)
    84 AMC Eagle 4dr sedan (Q-jet and HEI'd)
    AMC Eagle Evolution
    http://forums.amcevolution.com/
User avatar
84cutspreme
Postby 84cutspreme on Tue Jan 04, 2011 1:45 pm
I use dextron III in my 700, I was told to use it my trans shop buddies
User avatar
jrm81bu
Postby jrm81bu on Tue Jan 04, 2011 4:35 pm
Well you gotta figure when the 700r4 was introduced they didn't have Dexron V, VI, or even III. I would stay with Dex III, bowtieoverdrives recommends to not use sythetics.
81 Malibu
400(350 for now) 142 supercharger
700r4
3.73 posi 7.5
User avatar
tc1959
Postby tc1959 on Tue Jan 04, 2011 4:52 pm
Dexron VI is backward compatible with all Dexron capable transmissions according to GM.Com, However Dexron III is not compatible with new car transmissions. Hope this helps. Soon there won't be any Dexron III around It is being phased out just like Dex II was.
User avatar
megaladon6
Postby megaladon6 on Tue Jan 04, 2011 6:22 pm
i've not heard good things about synthetic ATF. Dex 4 is VERY good, and costs the same as 3--and is completely compatible of course--i've also heard that ford type F is a very good "performance" atf in gm transmissions.
87 monte ss t-top 200-4r trans. 383ci 4-bolt, 9.7: hypereutectics, forged rods, vortec heads, xe274 cam, Q-Jet-home modified, Evans NPG+ coolant
User avatar
84cutspreme
Postby 84cutspreme on Wed Jan 05, 2011 5:12 pm
I have heard the same, I believe Freddy Brown Race Transmissions uses Ford trans fluid in GM trans.
User avatar
1evilregal
Postby 1evilregal on Sat Jan 08, 2011 10:28 am
megaladon6 wrote:i've also heard that ford type F is a very good "performance" atf in gm transmissions.
it's basically what the b&m "trickshift" fluid is, but with a few other additives in it... something to do with the friction modifiers in the fluid, causing the clutch packs to grab at lower pressures... I could be wrong though, older minds play tricks! :mrgreen:
"A true soldier fights not because he hates what is in front of him, but because he loves what is behind him" G.K. Chesterson
there are two kinds of pedestrians: the quick, and the dead
1982 Regal "Gran Sport" project
1986 Cutlass Salon
Return to Chassis / Drivetrain / Suspension / Wheels
Who is online
Users browsing this forum: No registered users
