The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
Get the GBodyForum e-mail newsletter!, Contests, Events, Deals, Forum News and More!
It appears you're not logged in! Not a member? Registration's FREE and only takes a minute!
Register now or Log in to hide this ad block.
GBodyForum Supporting Vendor
Ignition stuck
Tech articles etc. for Electrical and Interior issues.
User avatar
85montanezSS
G Body Guru
Ignition stuck
Postby 85montanezSS on Mon Aug 05, 2013 8:26 pm
I really hope someone can give me the answer I need.I parked my car and when I went back and put my key in the ignition it won't turn like its locked.I put some WD in it to see if it was stuck but nothing I turn the steering from side to side while trying to turn the key and still nothing it just won't turn forward or backward what can I do to unlock it.
350 stock bottom,Flat top pistons,2.02/1.60 76cc Stock Heads Ported and polished,RPM Air Gap intake,650 Holley Mech,Lunati bracket master cam,Roller rockers,2004R,3:73 auburn posi,Headers,Flowmaster Super 40 mufflers with X pipe.
User avatar
carmangary
Re: Ignition stuck
Postby carmangary on Mon Aug 05, 2013 8:46 pm
Mine did that a couple of times when it sat in the hot sun for awhile. It was OK when it cooled down. I replaced the lock cylinder which seems to have fixed it. I couldn't see anything wrong with the old one, though.
User avatar
-83MONTESS-
Re: Ignition stuck
Postby -83MONTESS- on Mon Aug 05, 2013 10:06 pm
x2 on the lock cylinder. Mine was tempermental. I had to put the key in a certain speed and angle it a certain way to get it to turn. Nobody could start my car or turn the key but me :lol:
1983 Monte Carlo SS - 6.6L 400 SBC, TH400, 3:73
User avatar
85montanezSS
G Body Guru
Re: Ignition stuck
Postby 85montanezSS on Thu Aug 08, 2013 6:00 am
So what else can I check or do to fix this problem.How do I remove the lock cylinder if that's what I have to do.
User avatar
86 Grand prix
G Body Guru
Re: Ignition stuck
Postby 86 Grand prix on Thu Aug 08, 2013 6:03 am
If the car is turned off while the steering is in a bind it will lock the key. Try tuning the steering wheel and the key and see if it is in a bind.
1986 was 3.8 V6 Grand Prix "in process" Built 7.62, auburn posi, 3:42 gears, Moser axles. 700r4 with all the Transgo goodies, 1997 5.7 Vortec, stroked, LT4 Hot Cam kit, Edelbrock intake, 800 CFM Quadrajet, headers w/ Summit duals. 26,512 original miles.
User avatar
wonderboy24
Re: Ignition stuck
Postby wonderboy24 on Thu Aug 08, 2013 6:15 am
x2 turn the wheel and jiggle the key. it might take s bit but should come unlocked. it happen in my truck it seem liked every time i got in the dang thing.i did end up replacing mine as well. it can be fun to replace them. you will have to remove the wheel and dismantle the column to get the cylinder out.
User avatar
85montanezSS
G Body Guru
Re: Ignition stuck
Postby 85montanezSS on Thu Aug 08, 2013 9:55 am
I've tried the steering wheel and key thing for 2 days and nothing still locked the ignition will not budge I guess I might have to call a lock smith to come and replace it and see if that fixes the problem unless anyone else knows something else I can do.
User avatar
AlamoCity210
G Body Guru
Re: Ignition stuck
Postby AlamoCity210 on Thu Aug 08, 2013 5:02 pm
I don't know I this is related or not but some time ago before I worked on my column and ignition my key got stuck in there with the car running. After takin it all apart, there was this spring looking thing that had got bent up preventing me to turn the key. I'll see if I can find a pic. May or may not be it. I definitely say it ain't worth a lock smith.
Here's a pic of that spring thing.
Return to Electrical and Interior
Who is online
Users browsing this forum: No registered users
