The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
How To Remove Window Trim (with pics)
Articles about Body and Trim related issues.
User avatar
Hydros4life
Re: How To Remove Window Trim (with pics)
Postby Hydros4life on Mon Dec 05, 2011 4:40 pm
how about the small side window trim getting some new ones and tryn to find away to replace them without messing up my new paint job....
User avatar
cutlassguy
G Body Guru
Postby cutlassguy on Wed Feb 22, 2012 7:30 pm
same, i need to know also. can you post a video on youtube?
the difference between my wife and my fridge is my fridge doesnt fart when i take the meat out!!!
User avatar
mr evil
G Body Guru
Postby mr evil on Thu Feb 23, 2012 10:00 am
Hydros4life wrote:how about the small side window trim getting some new ones and tryn to find away to replace them without messing up my new paint job....
As I recall, the trim has pins that are actually part of holding the window in. If you remove the upper panel inside the car you will see the pins, they are held with speed nuts. Can't recall how many, but should be fairly easy to see. Once the nuts are removed, gently tap the pins outward-evenly around the window or else you could bend/snap the trim. Carefully cut away any sealant that may be sticking as you do this.
I remember this being a pretty straightforward operation once you dig into it. As for your new paint, if there is any overspray onto the trim, carefully use an edge around the trim to ensure you dont pull any paint away with the trim.
Carefully install new trim in reverse order 8)
Sorry, no pics or video of the procedure.
Rick
"Cleverly Disguised As A Responsible Adult"
1986 Cutlass Salon
Bone Stock 305, 2004r, 2.73
lesbaldridge
Postby lesbaldridge on Sat Feb 25, 2012 9:24 pm
marking this thread
All you florida guys, check out the florida members thread viewtopic.php?f=27&t=37660
my build thread viewtopic.php?f=10&t=35365
sons grand prix viewtopic.php?f=9&t=38906
zepplica
n00b
Postby zepplica on Sat Mar 17, 2012 2:20 pm
how about removing the trim inside the car on the front window?(85 la saber)
User avatar
cutlassguy
G Body Guru
Postby cutlassguy on Sat Mar 17, 2012 10:08 pm
any know how to remove the inside roof support plastic thing? lol basically the piece that goes from the dash to the roof. i triied removing a few screws i seen around it and i can get it to wiggle a bit, but the little tabs on the ends seem stuck on something and i cant get it loose. its a 1987 cutlass supreme.
User avatar
rmorman
Postby rmorman on Thu May 17, 2012 11:20 am
Hello!
I was wondering if this proceedure and tool also works on the rear window trim on a 3rd Gen Monte Carlo (1979)?
Thanks,
Russ
User avatar
ssbrewskyaz
Postby ssbrewskyaz on Mon Aug 20, 2012 12:37 pm
Very nice indeed Blake, sure better than the can opener I've been using. ... :lol:
timo22
Postby timo22 on Thu Feb 28, 2013 11:10 pm
Great post Blake! I tried practicing on some junk cars at the yard, but now have a good idea on how to do it when I find some nice donors. Thanks again..tim
User avatar
marz442
Postby marz442 on Tue Apr 16, 2013 7:59 pm
Very nice write up blake I just took my side 1/4 glass out.
Previous
Return to Body / Trim
Who is online
Users browsing this forum: No registered users
