The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
How to make a hood scoop from scratch
Eventually the goal is to have a repository of G-Body knowledge... eventually!
User avatar
Stoopud
G Body Guru
Postby Stoopud on Thu Aug 27, 2009 5:27 pm
I have been bragging about my hoodscoop on here for a year now, and never thought to post a how to, just-in-case someone else wants to give it a try. The goal is not to teach people how to copy mine, but instead the basic steps necessary to do your own.
1. The first and most imprtant step is to come up with an idea of what you want it to look like. If you are working alone a drawing is not important, but unless you have a plan, you will not know when it is right or when to stop (haha). Try to make sure that your ideas are not too complex, overhangs become a problem in one of the next steps.
I decided I wanted something like a GTO, but modified to match my cars lines. I had a number of ideas and it took more time to plan it than build it. My insperation...
I had never worked with fiberglass before so I had no idea how to do it. I got luck and Musclecars on Spike did an episode on how to make fiberglass fender flares for a Mustang (mentioning that this was what I copied is how I got on Spike. the following steps are my version of their instructions.
2. You will need to make a form. I used that green foam used to mount fake flowers (per Musclecars). You can get it at craft stores in verious sizes and thicknesses. Next you need to layout the location for the scoop on your stock hood. I used masking tape to and a Sharpie to mark the hoos. Make sure to find the actual center and work very careful to stay symetrical to it. Screw this up and the scoop is off center or crooked. Drink a bottle of alcohol for courage.
3. You will need to cut the foam to your shape. First make it contour to match the hood. I recommend hollowing as much of the bottom out as possible (1" deep should do) so you only have to make the edges level instead of trying to match the contour. You can use multiple pieces of foam if necessary, just tape it together with duct tape to make sure it fits together and lines up, use dowles to align it (I used broken pencils - they shove right in).
To shape the foam sanding works the best since it is hard to cut the stuff to shape with a saw. I used a broken hacksaw blad to cut the rough shape and sanded from there to get closer (rubbing a piece of the scrap foam against your piece works suprisingly well).
I cannot stress this enough - Make sure your foam is exactly how you want it. Make sure all of the surfaces are straight and recut anything you need to. It is much easier to work in foam than bondo.
Image - sorry it is blurry.
3. Tape the blank to the hood and make sure it is straight and even Then cover it in tin foil. Smoke 2 to celebrate.
4. start pouring fiberglass resin on the scoop and spreading fiberglass mat over it. brush the resin over the mat as you work. you need to make sure it is saturated. Extend the fiberglass at leat 1/2 to 1" onto the hood. I used 2 layers of cloth and a good chunk of a can of resin.
5. Let it set-up for a couple of hours, then go out and pop it off of the blank. Work carefully not to damage the scoop, but if it breaks at this point it is not strong enough anyway. This is the point where the complexity of the design or overhangs become and issue. You have to be able to get the blank out.
6. Now you have to attach it to the hood. First remove and discard the blank (unless you plan to make another - they can be reused). Now place the scoop on the hood exactly where you want it. Drill small holes around the base (the fiberglass that extended over the hood) and through the hood . Remove the scoop and apply adhesive (I used GM panel adhesive - same stuff the glue quarter panels on with). I held it in place while it dried with klicos and then replaced with rivits once the adhesive dried. you could probably just rivit right off.
7. Once it sets up you can start blending it in. First grind the base a little once the glue has dried to thin it down and apply bondo around the edge to fade it in (I went 6" in each direction). Now correct the surface imperfections to taste. I am picky and did not do a good enough job on the blank so it took me a few weeks of work. I think if I did it again I could save allot of time by doing the blank better.
8. Prime and check for flaws
8.5 re-prime before final paint
9. Thow a party and celebrate. Try to get on TV
http://www.youtube.com/watch?v=r_ZCKxKMqyo
Oh yeah, to make it functional cut a 12" hole over the carb before you glue it down. Then get a 14" drop base filter and a 9" filter. Put the 9" filter on the center of the 14" base and tighten down. Get some 4" hoodscoop foam from Summit and make it into a 14" OD circle and glue it to the 14" drop base where the filter normally goes, and cut to fit contour of hood. The opening in the 14" OD foam is 12" so it lines up with the hole in the hood to seal the air filter to the hood isolating the incoming air and is flexible enough not to cause problems
1983 T-Top PMD Seat Grand Prix - Phantom GTO Conversion
User avatar
monte olrac
Postby monte olrac on Thu Aug 27, 2009 7:42 pm
We got us a Spike TV celeb on the forum yeah baby, scoop looks good now lets see you build me one, i'll supply the beer and smokes
mickiez40oz@yahoo.com
Postby mickiez40oz@yahoo.com on Thu Aug 27, 2009 7:59 pm
That's cool! You gained national recognition.
Boy do I feel like a slacker now!
keep up the good work.
User avatar
Stoopud
G Body Guru
Postby Stoopud on Thu Aug 27, 2009 10:17 pm
Glad to see you guys like the hood. I want to see one someone else makes on here. I am trying to push the idea that it is easy to see more people try it. I like creativity. I want to see some neat ones from someone else.
I have had quite a few people recommend selling copies of mine, but I would have no idea what to charge and then I would not have the only one. If I ever make another, it will be a replacement one for this one on a glass hood. Then I will probably sell mine or trade it for something else I need (to someone not in Cleveland - I want the only one here).
User avatar
jrm81bu
Postby jrm81bu on Thu Aug 27, 2009 11:21 pm
Nice job! :notworthy:
I may try to make one again, but I need to fix the motor first. I will definetly take pics when i do.
81 Malibu
400(350 for now) 142 supercharger
700r4
3.73 posi 7.5
User avatar
mr evil
G Body Guru
Postby mr evil on Thu Aug 27, 2009 11:39 pm
Thanks for the tutorial Stoopud. Having no experience with this whatsoever, I wouldn't even know where to start.
I too would like somethign original, but not outlandish or unfitting, now I think I'll try this someday.
You mind if any Q's from people get asked here, or via pm if they're feeling sneaky about their plans :lol:
Thanks again, stuff like this is a real bonus on a forum.
Rick
"Cleverly Disguised As A Responsible Adult"
1986 Cutlass Salon
Bone Stock 305, 2004r, 2.73
User avatar
Stoopud
G Body Guru
Postby Stoopud on Thu Aug 27, 2009 11:46 pm
Of course I don't mind questions. As long as nobody minds mine. That is why we are all here. The more nice G's there are on the street, the more respect we all get.
User avatar
85 Cutlass Brougham
Moderator
Postby 85 Cutlass Brougham on Thu Aug 27, 2009 11:59 pm
Stoopud wrote:Of course I don't mind questions. As long as nobody minds mine. That is why we are all here. The more nice G's there are on the street, the more respect we all get.
And it is attitudes like that which make this forum such a wonderful little place in cyberspace! 8)
1985 Cutlass Supreme Brougham (ex pizza delivery beater with 240,000 miles):
355 Chevy- 9.5:1 compression, Comp XE 262 cam, World S/R Torquer heads with 2.02's, Edelbrock Performer, 800CFM Q jet, Camaro ram air system,Edelbrock headers, Comp Magnum roller tip rockers,TH 200 4R, 3.23 rear, aluminum hood, IROC steering box, poly bushings, Eibach springs, etc. Cutlass build thread here: viewtopic.php?t=4982
Also: The Thing That Won't Die-1998 Nissan Frontier, 340,000 miles of pizza delivery.
User avatar
maximus84
G Body Guru
Re: How to make a hood scoop from scratch
Postby maximus84 on Sun Sep 06, 2009 7:35 pm
:idea: Hey,you could go directly from making scoops to making speaker boxes & enclosures,then to fiberglass dashes and center consoles! :mrgreen:
78 Olds Cutlass Supreme,84 El Camino Conquista,79 Chevy Corvette,99 Mitsubishi Galant GTZ
User avatar
1evilregal
Postby 1evilregal on Mon Sep 07, 2009 8:28 am
I might not be building the scoop for right now, but gave me idea for the front bumper fillers.
can't stand the idea of a couple hundred bucks for 1 pair for the front. :blam:
love the scoop, and thanks for the instructions....never thought of flower foam!
"A true soldier fights not because he hates what is in front of him, but because he loves what is behind him" G.K. Chesterson
there are two kinds of pedestrians: the quick, and the dead
1982 Regal "Gran Sport" project
1986 Cutlass Salon
User avatar
MrHernandez
Postby MrHernandez on Thu Feb 11, 2010 3:10 pm
you hollywood types have no business here!! just fu*kin with ya lol nice scoop, i've also thought about making my own rather than spending $175 just for a scoop i'm just afraid the fiberglass will end up cracking after say a year or two although after seeing yours i'm leaning more towards making one
78 El Camino 305/350 Vortec top end with comp components
81 Cutlass Supreme 350/700r4 -my first car, now belongs to my 4y.o.
"Earlie Cuyler: What did I tell you about drinking underneath the age, huh?
Rusty: You said if I could afford to bring back enough for you then you don't care what I do. And it's my body and I can kill it however I want to. And America's about freedom."
User avatar
dogshit
Postby dogshit on Thu Feb 11, 2010 5:46 pm
Some slightly different ideas for us cheap bastards that like it cheap & easy. You can look at mine in my pics. I was not done with the engine bay etc at the time of those pics but you get the idea. I used the cheap easy $149 scoop or whatever you call it. You drill holes that the scoop covers and simply bolt it to your hood. It fit so snug and looked nice enough that I never considered glue or bondo. I also cut a hole in my hood and the back of the scoop and used cheap foam from Lowes but used a regular filter instead of a 9". I did this by cutting out a metal donut and pop riveting it to the bottom of a cheap open breather that I bought then glued the foam to it. Just a little different way of doing it.
In the muscle car era if it had a small block it was your moms car. When you turn your car on does she return the favor? Life's short enjoy your ride. Hybrid burns gas & rubber. Check out my photo album.
87 Olds 442, Blue on Metalic Silver with 275/60/15 drag radials on 15x8 442 wheels, 10-1 509ci Cadillac, 800cfm Q-jet, Performer intake, Street ported heads, 230@50 518 lift cam, Headers, Built 200-4R, 2800 stall lock-up converter, Electric fans & in-tank fuel pump, Factory AC, All factory guages work including tach & oil temp with the 509, Functional Hurst hood & rear spoiler, 36mm hollow sway bar, 3.42 posi 8.5, 17.0 mpg hwy, sold :(
87 Buick Grand National, Tuxedo Black w Chrome 275/50 drag radials on 15x8 GN wheels, 231 Buick V6, TE-60 turbo, Stretch intercooler, 42.5lb injectors, 3" downpipe, 3000 stall lock-up converter, Meth/water injection, 3.42 posi 8.5, 22 mpg hwy, original owner ~ Goal for both cars 11.8 ETs / 115 mph in the quarter reliably on pump gas
User avatar
Stoopud
G Body Guru
Postby Stoopud on Thu Feb 11, 2010 6:31 pm
Dogshit:
I like the scoop and the air cleaner. Your air cleaner set-up looks the same as mine except for scale, I almost went with the same set-up until I found the 9". It looks real cool. I am glad to see someone else on here has a neat scoop. Great to see creativity and functionality.
User avatar
dogshit
Postby dogshit on Fri Feb 12, 2010 1:57 pm
Thanks. Cool you tube video. On the functionality I never cared about it being ram air as much as rain safe and good as it gets fresh air instead of power robing hot underhood heat.
EDIT I modified my pics
art
Postby art on Wed Mar 24, 2010 7:52 pm
I have a question for both of you. When you cut the underhood bracing, was there any negative effect? I'm not sure I'm going to do a scoop (though the idea has crossed my mind), but I need clearance for a tall air cleaner element. I was going to cut the crossbrace and the one that goes towards the back in the center and leave the rest. Any thoughts?
Thanks in advance,
Art
Next
Return to How-To's / Knowledge Base
Who is online
Users browsing this forum: No registered users
