The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
GBodyForum Supporting Vendor
aftermarket a/c
Eventually the goal is to have a repository of G-Body knowledge... eventually!
oldscutt85
aftermarket a/c
Postby oldscutt85 on Sun Nov 07, 2010 7:50 am
does anyone make an aftermarket heat and a/c kit for g bodys,when i did the v8 swap i had pulled out all the wiring from he computer harness and i never found the harness that connects to my a/c so idk what i should do :cry:
79elky454ss
G Body Guru
Re: aftermarket a/c
Postby 79elky454ss on Sun Nov 07, 2010 7:58 am
The wiring under the hood or in the dash? either way I would find a pull a part junkyard harness. Is your car in Japan with you? I could get you one on a trip to the junkyard if you need it there. Thanks for your service!
79 elcamino SS454 tribute car in progress
oldscutt85
Re: aftermarket a/c
Postby oldscutt85 on Sun Nov 07, 2010 8:26 am
79elky454ss wrote:The wiring under the hood or in the dash? either way I would find a pull a part junkyard harness. Is your car in Japan with you? I could get you one on a trip to the junkyard if you need it there. Thanks for your service!
its the harness under the hood i couldnt find the connecter that goes to it,hell no i would never bring my car to japan especally how bad these people drive and it rains like every other hour lol. and your welcome
dan2286
Re: aftermarket a/c
Postby dan2286 on Sun Nov 07, 2010 8:56 am
Just try to find another harness if you have all the other parts. That harness isn't very hard to get out.
84 Cutlass
In many pieces right now.
70 Olds 350/350 trans
Just trying to make it driveable
red79vette
n00b
Re: aftermarket a/c
Postby red79vette on Sun Nov 07, 2010 9:01 am
Good question... I often wanted to add AC to my Camino..
Any one add a vintage air kit or sometning like it?
oldscutt85
Re: aftermarket a/c
Postby oldscutt85 on Sun Nov 07, 2010 9:55 am
red79vette wrote:Good question... I often wanted to add AC to my Camino..
i had checked out their website today but they only have universal kit for g bodies,i dont wanna spend the cash then find out that nothing fits.
User avatar
trog
Re: aftermarket a/c
Postby trog on Sun Nov 07, 2010 12:19 pm
try classic auto air...i worked there for years, and they can put together a kit that will work, better quality stuff also
never argue with an idiot---they will just drag you down to their level,and beat you with experience
User avatar
Mike P
G Body Guru
Re: aftermarket a/c
Postby Mike P on Sun Nov 07, 2010 12:32 pm
I’m doing a Hot Rod Air unit in my El Camino project. Here’s a link to the mockup portion.
viewtopic.php?f=13&t=12658&start=90
As far as I know HRA is now out of business, I do know some of their vendors still have some units still on the shelf…..problem is there would be no factory support recourse in the event of a bad part.
83 El Camino, w/78 Monte Clip
507 Cadillac, TH400, 9"
FE3X CLONE
Re: aftermarket a/c
Postby FE3X CLONE on Sun Nov 07, 2010 1:58 pm
Mike P wrote:I’m doing a Hot Rod Air unit in my El Camino project. Here’s a link to the mockup portion.
http://gbodyforum.com/viewtopic.php?f=1 ... 8&start=90
Yeah no kidding! I bought one of their evaporators through Summit Racing years ago. Last year I sent them my stock HVAC controls to be modified to work with their system. Found out in Janurary when I still hadn't received them that they were out of business.
It took a lot of tracking down by I was at least able to get them sent over to the company that normally does the work on them. After 14 long months I at least got my controls back.
Now I just hope nothing goes wrong with the evaporator otherwise I'll be pulling it out and hoping a Vintage Air goes in its place.
Andrew Geeting
1987 Olds Cutlass Supreme - FE3X Pro-touring project
EFI 455/T-56/4.30
Image_________________________________________________________________________________
Return to How-To's / Knowledge Base
Who is online
Users browsing this forum: Exabot [Bot]
