Just an FYI on the radiator drain plug. Righty tighty lefty loosy applies in this situation however it works in reverse. By tightening the petcock your actually opening it up to let the fluid out.
Something else to keep in mind is when you do get the manifold off, stuff some rags in the intake ports of the heads and lay a towel in the lifter valley to keep any junk from getting into the engine while you clean the surfaces.
You may also find it makes the process easier by removing the oil fill tube at the front of the block. It just takes a couple of smacks with a rubber mallet and you should be able to wiggle it out. To put it back in, just smack it with the rubber hammer.
Without doing that it makes it a bit tought to get the intake to sit straight the first time. You'll be hitting that tube and the distributor.
