GBodyForum Supporting Vendor
Removing the polution control?
Eventually the goal is to have a repository of G-Body knowledge... eventually!
User avatar
bourbon
G Body Guru
Postby bourbon on Fri Sep 26, 2008 4:41 am
What all is involved in removing the pollution control stuff on my 83 regal, non a/c? i see the pump, and the black plastic "can" but the driver's side fender, and i see the pump is on a dedicated belt. but is there anything else i need to know/remove? and is it a good idea? Now that my hood is flipped, i need to clean up my engine compartment some.
thanks
1984 Monte Carlo SS -
View my build thread - http://www.gbodyforum.com/viewtopic.php ... I3aR2t5mSM
2001 Dodge Neon
2008 Lincoln Navigator
User avatar
85 Cutlass Brougham
Postby 85 Cutlass Brougham on Fri Sep 26, 2008 2:48 pm
Well...it's illegal and carries stiff fines if you are caught and the agency dealing with it wants to be nasty about it. That being said, much of the equipment is not detrimental to performance when there, but will throw codes in the computer (if your car still runs it) when removed.
1985 Cutlass Supreme Brougham (ex pizza delivery beater with 240,000 miles):
355 Chevy- 9.5:1 compression, Comp XE 262 cam, World S/R Torquer heads with 2.02's, Edelbrock Performer, 800CFM Q jet, Camaro ram air system,Edelbrock headers, Comp Magnum roller tip rockers,TH 200 4R, 3.23 rear, aluminum hood, IROC steering box, poly bushings, Eibach springs, etc. Cutlass build thread here: viewtopic.php?t=4982
Also: The Thing That Won't Die-1998 Nissan Frontier, 340,000 miles of pizza delivery.
User avatar
78mali350
Postby 78mali350 on Fri Sep 26, 2008 2:51 pm
depends on state correct? not that i care. But i tore all that out of the malibu. but i don't have to deal with emissions either. one good thing about iowa i guess
1978 Chevy Malibu Classic: 350 Crate Swap, Turbo 350 Transmission, Flowtech Full length Headers, Flowmaster Series 40 mufflers, Tru-Dual Exhaust, Northern Autoparts Racing Aluminum Radiator, Goodmark 2in Cowl Hood, Jasper Pearl Paint Job, Pioneer Receiver with Pioneer 6x9 speakers, Billet Specialities Vintec Wheels
User avatar
Phoenyx
Postby Phoenyx on Fri Sep 26, 2008 3:00 pm
It's nice up here in Canada too. Most people up here remove emissions and cats from our cars.
1980 4-door Malibu Classic
-355 10.5:1, worked over L82 Corvette 202 heads, 274 Energizer hydraulic cam, MSD Streetfire distributor and wires, Edelbrock 625?cfm carb (temporary), shorty headers, 2 1/2" (or maybe even 2") full duels (2 1/2" to come this summer)
-B&M TH350 with 2400 stall
-7.5 with 4.11 limited slip, rebuild drum to drum with support cover
-15" steelies with 24 1/5" tires
-Edelbrock boxed lowers, double adjustable uppers, anti-hop bars, and tubular braces
-jounce bars, GP bar (not installed yet), rad support braces, fender to support braces
User avatar
bourbon
G Body Guru
Postby bourbon on Fri Sep 26, 2008 3:26 pm
yeah, i have no emissions here either so im not worried about it. so will the check engine light be on?
2001 Dodge Neon
Uncletruck
G Body Guru
Postby Uncletruck on Fri Sep 26, 2008 3:53 pm
Only cars model year 1975 and older are emissions exempt in PA Bourbon, so you'll have to wait a few years to pull the emissions stuff UNLESS you register the car as antique/classic, then it's exempt. Even in the regions that don't do the tailpipe test, the emissions equipment has to be present if the car is newer than 1975- it doesn't have to function, but has to be there on the car physically. That's the law, I'm sure there are those shops out there that might bend or break it, but that's what is written.
-UT-
1978 Pontiac LeMans sedan with Buick 231 V6
2007 Toyota Tacoma 4x4
http://gbodyforum.com/photos/index-10974.html
User avatar
bourbon
G Body Guru
Postby bourbon on Fri Sep 26, 2008 4:32 pm
Uncletruck wrote:Only cars model year 1975 and older are emissions exempt in PA Bourbon, so you'll have to wait a few years to pull the emissions stuff UNLESS you register the car as antique/classic, then it's exempt. Even in the regions that don't do the tailpipe test, the emissions equipment has to be present if the car is newer than 1975- it doesn't have to function, but has to be there on the car physically. That's the law, I'm sure there are those shops out there that might bend or break it, but that's what is written.
-UT-
i didnt think we had it here, but i cant get the car through a normal inspection anyway.
2001 Dodge Neon
User avatar
megaladon6
Postby megaladon6 on Fri Sep 26, 2008 4:55 pm
some of the emissions equip you do want to keep. the PCV and the carbon canister should stay hooked up. the EGR system should be blocked off if you get rid of it, just disconnecting the lines can cause issues. and beware of anything hooked up to manifold vacuum, make sure it's completely sealed. the last thing you want is multiple vac leaks.
87 monte ss t-top 200-4r trans. 383ci 4-bolt, 9.7: hypereutectics, forged rods, vortec heads, xe274 cam, Q-Jet-home modified, Evans NPG+ coolant
User avatar
beermonkey9417
Postby beermonkey9417 on Mon Feb 02, 2009 6:20 am
here in chicago if yer cars a 95 or older you have to pass emm. once or pay to say you passed and then you never have to worry about it ever again. i got arrested in my '94 saturn twice for not passing emmitions, once when i was in the army, they said my license was suspended, even tho it was in my wallet. so i called cook county and said i was in upstate ny and couldnt go back to il to pass yet. 6 months later i was back home and got pulled over for a sticker in my back window, and was arrested because i didnt pass emmitions. so i took my car to a mecanic and paid 600 bucks to get a new down pipe and cat. i still didnt pass emmitions but i showd the 600 dollar bill i had paid and they said ok heres yer license back, yer exempt now. thats some bullshit! i wanna kick jessy white right in the bag of doing that to me. before that i have never been arrested or handcuffed. handcuffs are not made for comfort, some of you may or may not know this. just my $0.02
"Gimmie a pickle jar, I'll open that bitch up like a Motherfucker!"
Save Water, Drink Beer! Save A Tree, Eat A Beaver!
-'78 el camino, 307sbc, 14014416 heads, 1.6 roller tip rockers, holley 600 cfm carb, monte carlo interior, 200-4R, rockford 4.11 posi PO-MutherF#$kin-S viewtopic.php?f=7&t=8386
-'94 saturn sl1, 1.9l tbi, 85hp, sony explod headunit, 1200w sony explod amp, 2.4 farad cap, no muffler, jvc 3-way 6 1/2" all around, kicker 12" twin voice coil sub, 15" x 8" chrome rims. - R.I.P.
-'99 infinity I30 3.0 V6 on 17inch rims, 5 speed, stock so far...
-'07 47cc 2 stroke cag daytona, ported carb and #72 jet, stage 2 carbon fiber reed, race tuned exhaust, shwinn speedo, toyota badge, meat hook pegs, street fighter.
http://www.youtube.com/watch?v=efzbqvwBF9E
Return to How-To's / Knowledge Base
Who is online
Users browsing this forum: No registered users
