The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
Get the GBodyForum e-mail newsletter!, Contests, Events, Deals, Forum News and More!
GBodyForum Supporting Vendor
G body regal
Keep it clean! :)
Someone_Much_Cooler
G body regal
Postby Someone_Much_Cooler on Sun Feb 27, 2011 4:47 pm
Are the rear aluminum inner bumpers interchange able between g body models?
Can I convert to the s10 manual steering with a grand national? Is it recommended?
Like our group 4 ppl in the North East region that are Gbodys enthusiasts! Stay in touch for our regular cruises & meets, local car shows & cookouts, fundraisers & charity events and various types of racing events http://www.facebook.com/KingsRansomEntertainment
User avatar
Blake442
Re: G body regal
Postby Blake442 on Mon Feb 28, 2011 3:32 pm
Someone_Much_Cooler wrote:Are the rear aluminum inner bumpers interchange able between g body models?
No. If they came off a Regal, they will only fit a Regal.
Yes, you can do that swap on any G-body. As for if it is recommended, I wouldn't.
The HydroBoost brakes on the Grand National are run off of hydraulic pressure supplied by the power steering pump.
So in addition to the extra steering effort to save just a couple horsepower, you would also have to covert the brakes to either manual, or a traditional vacuum booster set-up. Sounds like an awful lot of work for such a small gain.
'85 Oldsmobile 442--Olds 455-TH400
'83 Oldsmobile Cutlass Cruiser--Chevy 350-TH350
Past G's--'81 Regal, '84 El Camino, '79 Cutlass Supreme, '87 Cutlass Salon,
'81 Monte Carlo, '81 El Camino, '79 Malibu Wagon, '81 Century Estate Wagon
Someone_Much_Cooler
Re: G body regal
Postby Someone_Much_Cooler on Mon Feb 28, 2011 11:25 pm
im sorry the regal already has the vacuume brake conversion
User avatar
canadiantbone
Re: G body regal
Postby canadiantbone on Tue Mar 01, 2011 12:08 am
the s10 manual box will fit into the regal. I have one if you are interested.
350 - TH350 7.5 with 3.73 gears posi
245/45/17 Front 275/45/17 rear
anything bolted on must function !
User avatar
custom442
Re: G body regal
Postby custom442 on Tue Mar 01, 2011 12:13 am
depends on what you plan to do with the rear clip. If you want a stock rear, then no
86 cutlass supreme 383, 31% finished
06 silverado 262 ci s/c, 12psi and broke head unit
User avatar
stomis
G Body Guru
Re: G body regal
Postby stomis on Tue Mar 01, 2011 11:30 am
I thought that the Cutlass and Regal were the same base body. w/ different ass and front clips?
1986 442: Blue/Silver/Blue, Astro Roof, B&M Megashifter, Boxed Control arms, Poly Bushings
Coming very soon: Budget 383 vortec
User avatar
joe_padavano
Re: G body regal
Postby joe_padavano on Tue Mar 01, 2011 1:30 pm
Blake442 wrote:
Someone_Much_Cooler wrote:The HydroBoost brakes on the Grand National are run off of hydraulic pressure supplied by the power steering pump.
I'm not a GN expert, but my friend's all original 86 GN has a factory-installed Powermaster brake system. The hydraulic booster is self-contained and uses a small electric motor to provide the hydraulic pressure for the booster, not the PS pump. In fact, the Powermaster uses brake fluid for the booster working fluid, not PS fluid.
Joe Padavano
64 Jetstar 88
66 442 conv
68 W-30
69 H/O
69 442
70 W-30
72 442
78 Camino
86 Caprice SW (w/307)
User avatar
Blake442
Re: G body regal
Postby Blake442 on Tue Mar 01, 2011 2:48 pm
The only things that the Cutlass and Regal share is the doors. Everything else is different.
User avatar
Blake442
Re: G body regal
Postby Blake442 on Tue Mar 01, 2011 2:51 pm
Joe, I think we're both right, as there are two different set-ups that were used on the GN's.
The earlier hydroboost, and the later powermaster.
Either way, for the subject at hand, it doesn't matter since this guys car already has vacuum brakes on it.
Someone_Much_Cooler
Re: G body regal
Postby Someone_Much_Cooler on Thu Mar 17, 2011 5:41 pm
yeah basically im jus gonna buy a bumper from brian @gbodyparts
Return to General Discussion
Who is online
Users browsing this forum: No registered users
cron
