700r4 good with 3.73 rear gears ???
laman1982
Mar 16, 2011
95
phoenix az
700r4 good with 3.73 rear gears or not whats best :bump: ???
kornball426
1,439
286
83
Philadelphia, PA.
there's no answer to the question "what's best?" but if you want to run fairly steep rear gears like a 3:73, and you want to have any kind of highway mileage then you will need overdrive and the 700R4 is a good choice. It's basically a TH350 with an extra gear for highway mileage.
laman1982
Mar 16, 2011
95
phoenix az
well thats what came stock with my monte 3:73 rear gears i see alot people running 4:10 or 4:56 rear gears i just wanted some opinions ?
9a pilot
40
6
904 area code
Yeah it's a good street gear. It's an even better street gear for a 2004r. The best all around street gear for a 700 is 3.42.
At least in terms of the gear multiplication in 1st & for cruising in OD.
woodss
15
Depends on your car and its use and your desires but its a good streetable setup.
laman1982
Mar 16, 2011
95
phoenix az
STRIP AND STREET
-83MONTESS-
4,570
967
Bellevue, Ohio
laman1982 said:
STRIP AND STREET
For street and strip a 700r4 with 3.73 gears would be the ideal setup IMO. Get a nice shift kit and you'll be having fun in no time! If your not relying on the gears as much as the torque of the engine to get you moving then you could go with 3.42s or even 3.08s (maybe). But keep that overdrive transmission! You will regret it otherwise :mrgreen:
laman1982
Mar 16, 2011
95
phoenix az
-83MONTESS- said:
laman1982 said:
STRIP AND STREET
thanks for the info! but now i need posi with 3.73 gears do you what cars had them ? that would fit right up with my 87 monte carlo ss??
-83MONTESS-
4,570
967
Bellevue, Ohio
laman1982 said:
-83MONTESS- said:
laman1982 said:
STRIP AND STREET
Look mainly for 85-88 Monte SS's. Thats where I got mine and they are less rare than alot of the other Gbodies that had them.
patmckinneyracing
2,021
36
San Antonio, TX
My rear end came from an 86' monte ss and has the auburn posi with 3.73 gears. Swapped out the stock ring and pinion for a set of Yukon 3.73's since the stock set chipped a tooth.
I have a 700r4 with a 2500 stall. The car hooks great and accelerates like a bat out-a-hell.
