GBodyForum Supporting Vendor
Brake proportioning valve
Keep it clean! :)
srercrcr
Postby srercrcr on Wed Jul 30, 2008 4:04 am
I think mine is defective cause I'm not getting any pressure to the front calipers, just the rear. I wouldn't be opposed to defeating the separate front to rear systems...like in the good old days. Why couldn't I replace it with a simple junction block, all lines merging at that spot? Anybody seen such a block offered in the aftermarket?
Steve R
78 Grand Prix LJ - one owner
I sell GM service manuals and some GP parts
User avatar
pontiacgp
Postby pontiacgp on Wed Jul 30, 2008 8:37 am
your rear brakes will locking up every time you hit the brakes if you aren't using a proportioning valve...
Free Shipping on Orders Over $75!
User avatar
85 Cutlass Brougham
Postby 85 Cutlass Brougham on Wed Jul 30, 2008 10:37 am
Plus, the prop valve also contains a residual pressure valve to keep the rear brakes in adjustment. If you remove this, the wheel cylinders will retract too far and the back brakes will fail to function.
1985 Cutlass Supreme Brougham (ex pizza delivery beater with 240,000 miles):
355 Chevy- 9.5:1 compression, Comp XE 262 cam, World S/R Torquer heads with 2.02's, Edelbrock Performer, 800CFM Q jet, Camaro ram air system,Edelbrock headers, Comp Magnum roller tip rockers,TH 200 4R, 3.23 rear, aluminum hood, IROC steering box, poly bushings, Eibach springs, etc. Cutlass build thread here: viewtopic.php?t=4982
Also: The Thing That Won't Die-1998 Nissan Frontier, 340,000 miles of pizza delivery.
Return to General Discussion
Who is online
Users browsing this forum: Clone TIE Pilot
