82 Malibu wagon with caddy 500
pyrofenix
34
8
Atlanta, GA
I just picked up a Malibu wagon with a big block Cadillac 500 already swapped in. The front suspension is a little low (don't think the previous owner did anything to the suspension when dropping in the extra weight).
I don't want it to sit real low or anything but not at stock height and I'm not sure what I should get for the front suspension - 550# springs? More? :?: I'd welcome all suggestions!
I'll post pics tomorrow.
green79gp
38
Eugene,Ore
would love to see it
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,174
9,776
Gainesville, Fl
I'd also love to see this wagon. I knew of one other 500 cu.in. Caddy powered Malibu wagon. It was painted a flat rootbeer color with black painted wheels. It was very sinister looking. I think the guys name was Chris...I can't recall.
But the last I heard, this car was for sale.
Longroof79
Oct 14, 2008
12,174
9,776
Gainesville, Fl
Nice score, man! I like it. It must be a blast to drive. Thanks for posting up pics.
What plans do have for it?
You might also want to consider a fan shroud or electric fans. Also, as far as front springs. MOOG #5660 S-10 springs might work nicely with a heavier Caddy motor.
pyrofenix
34
8
Atlanta, GA
It had several small radiator leaks so I have already purchased a new aluminum radiator and will be going with a pair of electric fans to help keep it cool.
Other than the going through the front suspension, it's just got a bunch of small things that need to be done. Once I have those, i'll re-address my plans.
Gotta keep the plans small until after the girlfriend becomes a fiance/wife.
Bonnewagon
Lost in the Labyrinth
10,563
14,293
Queens, NY
Cool car! A super-sleeper. When I put a Pontiac 400 in my 81' Malibu wagon the front end scraped the ground. I used 77' TA springs with 3/4 of a coil cut off. Without cutting, the nose pointed to the sky, like there was no motor at all. I cut a 1/4 coil at a time and watched how she sat. At 3/4 of a coil, it was about 2" taller than stock, and a VERY firm ride, yet compliant. A lot of work to do it incrementally, but worth it. As I always say, you can cut more off, but you can't add any on. And there is no formula for "this spring will give you that height" because every car/motor combination is different. Good luck with the car and the wife!
Peter
1,175
74
48
MA
awesome.
pyrofenix
34
8
Atlanta, GA
Thanks, I definitely want to keep the sleeper feel.
I really love having the big block under the stock hood. No cowl to give anything away. A stock looking fiberglass hood would be nice to shed some weight would be good too though! So many ways to go...
