1979 Bu Wagon on 18'' Boss 338s...
Nozer
134
2
16
Macedon , NY
well I went and dun it.....i cant remember the backspacing on the wheels off hand but .. the rears are 18x9.5.. fronts are 18x8 ..i used a jegs 2 inch drop spindle with a 1 inch drop hotchkiss coil up front and a 3 inch drop coil out back.. the tires rub slightly on the rear frame so i bumped it out slightly with a 1/4 inch spacer. all it needs.. the tires tuck nicely..nitto nt555 tires... 235/40 up front and 275/75 in rear..
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,176
9,778
Gainesville, Fl
New wheels look good, man.
The car is sitting nice with the new stance.
liquidh8
Love those wheels, they are on my wish list for the wagon.
oranGekrate
199
109
Fredericksburg, VA
Man looks soooo sweet. Love that look. It looks like from the info I have from Boss, your fronts are 4.5 bs & rears are 5in bs...
Did you roll the fender lips at all? How about front liner rub? Any? Also, did you have any hub issues? I know the chevy trucks at one time needed to grind the hubs for fitment, I think they corrected that though. What shocks are you running? Sorry about all the questions, but I REALLY like that look and maybe one day I'll go that route. :mrgreen:
Nozer
134
2
16
Macedon , NY
well just today i realized i may have to roll the rear lips..got a slight slice in a new tire :wtf: from it so i took the spacer off and that helped.. also yeah the hub on one side was a size issue but it all depends on what brand bearing you get..pretty much a non issue if you run a slight spacer and lengthen the wheels studs.. the originals are super short..front are stock shocks and rear are a little shorter than stock..A friend measured and ordered them at his shop while i was at work so not sure on the size.
