Need info on converting power to manual steering
84hurstdarrin
6
I have a 1988 Monte Carlo SS and want to convert the power steering to manual steering , what parts do I need to get to do this, I heard a S-10 manual gearbox? From what years S-10 ? Any other parts needed
86Cutlass383SR
720
6
Sesser, IL
mid 80's to early 90's would be the ones to look for. Not sure on the exact year breaks.
The above is all you need to do. I think the pitman arm length may be differant so get it too so you can compare lengthwise.
Chris Van
515
4
16
Middle Ga.
The above is correct. And it's a direct bolt on replacement.
Bonnewagon
Rocket Powered Basset Hound
10,540
14,217
Queens, NY
I've never compared an S-10 arm with the correct manual G-body pitman arm, has anyone else? I'm curious if it is exactly the same or "close enough"? I used the 81' Malibu arm that came with the car because the crummy 600 series steering box (snap ring cover) was the same smaller diameter as the manual box. The 800 series box (4 bolt cover) is larger.
skulledmonte84
426
6
near Clearfield pa
What's the reason for doing this ? it's goona be harder to steer lol Someone please explain
knowyourenemy66
24
Panama City, Florida
I have an '78 regal [street car] that I converted. I used the box and arm from an '85 s-10. Both arms are the same in my setup. This may not be true in all situations. The advantages are; no pulley drag from the pump to the crankshaft [free horsepower] and less weight [less weight is faster]. I have a very light regal, 2500 lbs. It has been gutted, has a fiberglass front clip and I run 4" wide tires on the front. Steers easily with one hand, just like power steering even when sitting still.
skulledmonte84
426
6
near Clearfield pa
Thanks, That should clean the engine bay up some more,not having a pump or the lines down in there,I Think i read some were on here that They only use 2 bolts an not 3 is that right ?
knowyourenemy66
24
The '85 manual box I used has 3 bolts. Bolts right in without any problems. After I took the installed pic, I did go back and replace factory rag joint and shaft with a double D shaft and aftermarket u-joint. I replaced it because I didn't like the feel at the steering wheel. Before swapping over, I greased the box [internally]. To grease it, I removed the 4 bolts and top cover and filled with quality wheel bearing grease. To tighten up play, after installing the box, just loosen the center jam nut and turn the center bolt [clockwise, if I remember correctly]. Adjustment removes play not stiffness. Stiffness is affected by frontend weight and tire width.
skulledmonte84
426
6
near Clearfield pa
That looks good,i think i may start looking for one,i got 6' inch wide tires or wider on there,That going to be an issues ? i dont plan to change my rims,there 8" i plan to do the jeep streering shaft upgrade as well
