GBodyForum Supporting Vendor
Fiberglass Hood Hinge Help
Faulk21NG238
Postby Faulk21NG238 on Thu Sep 06, 2012 1:25 pm
I have a 1980 Malibu with a fibersgass 4 inch cowl hood from fiberboy products. Hinges are attached, but the springs have been removed. Everytime I need to get under the hood I have to prop it up or have someone hold it. Does anyone know of a light weight sring that can be used that replaces the circle spring (sorry dont know the proper name for it) that came off of the hinge?
I did a search to see if there are any postings about this. I found where some guys were using gas springs to open and close their hoods. I cant find any examples of this though. Anyone have pictures of this? Or any ideas of what can be done to keep my hood open?
User avatar
t01blaze
G Body Guru
Re: Fiberglass Hood Hinge Help
Postby t01blaze on Thu Sep 06, 2012 1:29 pm
User avatar
80ELCAMINOFLAKE
Postby 80ELCAMINOFLAKE on Thu Sep 06, 2012 1:31 pm
I can be wrong, but i think with those fiberglass hoods., you cant put springs or latches, those were made for either pop off hoods, or with hood locks...u will have to drill a hole and put those pins in to hold the hood down....chime in guys :mrgreen:
80ZBABIEZ CC
1980 CHEVY EL CAMINO 305/350TRANS/ POSI/ 3.73 GEARS SOLD!!
1978 CHEVY MALIBU 2 DR 350/200r4 TRANS
User avatar
80ELCAMINOFLAKE
Postby 80ELCAMINOFLAKE on Thu Sep 06, 2012 1:32 pm
t01blaze wrote:http://www.maliburacing.com/forum/viewtopic.php?f=14&t=105647
I think hes talking about the spring in front of hood thats not closing correctly....not the hinges..
80ZBABIEZ CC
User avatar
80ELCAMINOFLAKE
Postby 80ELCAMINOFLAKE on Thu Sep 06, 2012 1:37 pm
something like this u might need....
80ZBABIEZ CC
User avatar
Lowproelco
G Body Guru
Postby Lowproelco on Thu Sep 06, 2012 1:39 pm
Also check out this site sells everythang u need http://www.up22.com/accessories.htm
User avatar
454muscle
Postby 454muscle on Thu Sep 06, 2012 1:40 pm
Little confused. But if you're talking about when you pull the hood latch to pop it -- that is a function of the "hood pop spring" (as opposed to the coil springs that normally go in the hinges of the hood -- their function is to hold the hood up when it's fully extended).
Ebay has tons of hood pop springs. Better yet just hit your local auto wreckers -- that's where I got mine, off a GP. Sanded it, primed and painted and it works very well for my 4" cowl fiberglass hood.
Ricers can't scare others by just idling.
"...back in the day, if you opened the hood and it didn't have a big block, it was your mother's car." - Pat Musi
Former G-body Of The Month winner.
Project RAWDOGG: 1984 Pontiac Grand Prix Pro Touring
Build Thread | Stolen Thread | Cardomain | Youtube | "The G-BODY Poem"
'84 Pontiac Grand Prix T-top, Edelbrock 555 BBC EFI crate motor, TCI Superstreetfighter 4L80E, Currie "Detroit Locker" rear w/3:89 gears, Ridetech Street Challenge air ride kit, Flowmaster Super40s, Custom body kit, Black leather heated power bucket seats, Power Mirrors, Custom dash bezel, Autometer Cobalt gauges, G-tech Pro EGS tach, Dakota Digital Climate Control with AC by Vintage Air, B&M Megashifter, Custom center console, MB Quart components, Rockford Fosgate T2 subs, Night Rider nav GPS unit, switches...
Faulk21NG238
Postby Faulk21NG238 on Thu Sep 06, 2012 2:01 pm
Sorry for the confusion. I am speaking of the hinge spring. The hood latch is removed and hood pins have been installed. I want to be able to remove the pins, lift up the hood and it stays open. The original hood hinge is bolted to the hood just like the factory hood would have been. There is nothing to keep the hood open unless I prop it with a stick or have someone hold it open for me.
Attached is a photo of the spring I was talking about in my original post. The spring that I took off of the hinge looked like that. Hope this helps with the confusion.
User avatar
80ELCAMINOFLAKE
Postby 80ELCAMINOFLAKE on Thu Sep 06, 2012 2:28 pm
Ahhhhh got ya, yea ur best bet is the junk yards :mrgreen: :wink:
80ZBABIEZ CC
jlcustomz
G Body Guru
Postby jlcustomz on Sat Sep 08, 2012 2:41 pm
Years ago when I had a normal opening harwood hood, I completely removed the factoryspring mechanism & added gas shock 10mm pivots to front of hood hinge. I think some later g-body's like regals came with shocks. Sorry I never kept my shock #'s or took pics, but it's not a big fabrication project.I hand picked a pr of shocks from an auto parts store by compressing & judging strength & length (approx 10 to 12" overall??) . Made lower mounts to attach to fenderwells with a few extra holes for adjustment. You can do a little simple figuring for location by putting tape on sides of hood near hinge & figure shock lenth open & compressed & how high you want to open hood & mark your locations. Besides stronger or weaker shock choices, remember that closer to hinge pivot means more movement but less strength & vice versa.
This isn't that hard with a little figuring & shock studs are available separately, got some from napa recently. Trust me this is very simple compared to my latest hood hinge mechanism.
No true hot rod is ever finished. If it doesn't command respect, fear will do.
http://s1094.beta.photobucket.com/user/ ... 2720766585
http://www.youtube.com/watch?v=n3mL8ze7 ... ature=plcp
Next
Return to Chevrolet Monte Carlo / SS / Malibu
Who is online
Users browsing this forum: No registered users
