Hello Gbf. I have a 78 monte and for some strange odd reason it doesn't want to charge. The gen and oil light comes on when you first turn the key then goes off when started like normal. I have replace the alt. Had it test at two different places and it was good. With the old one it had the same issue but when you pull the battery cables off the terminal the motors doesn't die. Same with the new one. I replaced the battery but it drained it down dead after 15 min of driving. I replaced the battery cables and clamps. Replaced the worn grounding cable that comes off the negative batt cable. Someone told me to run a cable from the positive batt cable to the alt. That didn't help neither. The gen light does not come on during this either. I'm going to check the belt for tightness and recheck the ground from the negative batt cable. This is my first chevy and is very odd to me after dealing with fords and datsuns almost all my life.
