Which gear ratio for best MPG
Collector
Aug 28, 2011
61
17
8
Hoofddorp,Netherlands,Europe
Hoping to get some help in sorting out my gear ratio, have a stock monte carlo from 1979, 305 stock engine running on LPG, th200 and i dont know what ratio the diff has. (GM 7.5" 10 bolt)
Present diff has a nasty "boink" noise know and then, and was reason for me to buy a spare diff, the spare diff is getting an overhaul from me with fresh bearings and seals, so when i get my MC on the 4 post i can swap the rear axle.
I have also bought an TH2004R which i am going to swap with the present TH200.
The spare diff says on the ring gear 15-41 if i am correct thats a 2.73 ratio
If i want to change the ratio is have a choice in these ratio's (according to rockauto)
2.73
3.08
3.23
3.42
3.73
3.9
4.11
4.56
At 9 dollars the gallon over here, a little fuel efficiency would be very nice, can someone explain what happens when i change my ratio to (example) 3.42.
I am dutch so its a PITA to convert from inch to metric and vice versa so please keep the answers as simple as possible
tlonz88442
2.73s- 3.23s is keeping mpg in mind but if u go up past 3.23s to 3.42s that should be easing up on performance and decreases mpg , if ur not hotrodding but only crusin with a small block then ur org. Gears is what u need
Collector
Aug 28, 2011
61
17
8
Plan is to use a TH200R4 transmission, and i dont want to smother the engine while in 4th gear and in lockup.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
the spare carrier you have is a 2 series so that limits you to a 3.08. Any higher you need a series 3 carrier or a spacer or thick gears to make them work on a 2 series carrier. I chose the 3.08 cause I think it's a nice gear for city and highway, especially with a stick so I'm not shifting every 20 feet
FE3X CLONE
2,714
47
48
Ohio
Your stock gears are likely something in the 2.14 to 2.41 range.
Since you'll be using a TH-2004R you could use the below ratios that would keep you in the same ball park as your current 3 speed:
3.73x.67 = 2.49 final drive
3.42x.67 = 2.29
3.23x.67 = 2.16
Collector
Aug 28, 2011
61
17
8
3.42x.67 = 2.29
3.23x.67 = 2.16
This is how i look at this
3.73 is diff gear ratio x 0.67 is gear ratio from the TH200R4 in LU that makes the final gear ratio 2.49 am i correct ?
If this is the case then i can do the math from here, Thanks for you're patience and the help
[edit] Ordered 3.42 "thick"gears from rock auto found this site who is very good at explaining everything http://www.crawlpedia.com/thick_gears.htm
BOWTIEKID
7
2
3.42x.67 = 2.29
3.23x.67 = 2.16
That's what I would have picked, at least it won't fall on it's face in city traffic. How expensive is the LPG over there?
Oct 14, 2008
8,806
7,746
Melville,Saskatchewan
I run at 1850 rpm at 100 km/hr with a short 25.6" tire (stock height). I also have 3.42 gears and a 2004r trans.
jacobdavis1979
700
14
If your going with an overdrive transmission then 3.42 will give you nice power and you should cruise at 60 mph about 1900 with i think a 26 inch tall tire. My math may not be correct but that should be about right
Olds307 im sorry i just saw your reply i promise i wasnt trying to rip that from you lol
cyrus_the_great
237
16
IRAN
just wanna join this good topic .. i have 2.41:1 and 2004R , on highway with 110km/h speed i can not hear the engine even :mrgreen: tachometer dosent work so i don't know exact RPM
