The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
Get the GBodyForum e-mail newsletter!, Contests, Events, Deals, Forum News and More!
It appears you're not logged in! Not a member? Registration's FREE and only takes a minute!
Register now or Log in to hide this ad block.
GBodyForum Supporting Vendor
????smog pump removal????
Eventually the goal is to have a repository of G-Body knowledge... eventually!
88supreme
n00b
Postby 88supreme on Sun Sep 27, 2009 11:27 pm
need some help wanting to remove my smog pump and i am trying to find out what is exactly involved and what i will need to do this
88supreme
n00b
Re: ????smog pump removal????
Postby 88supreme on Mon Sep 28, 2009 1:10 pm
no help?
dan2286
Postby dan2286 on Mon Sep 28, 2009 1:32 pm
What car and engine?
84 Cutlass
In many pieces right now.
70 Olds 350/350 trans
Just trying to make it driveable
88supreme
n00b
Postby 88supreme on Mon Sep 28, 2009 10:51 pm
its the 307 in a cutlass supreme
User avatar
patmckinneyracing
Postby patmckinneyracing on Mon Sep 28, 2009 11:00 pm
Got a pic of the engine bay by any chance? I've removed 3 of those smog systems from both my malibu, a 80's silverado, and an 85 dodge 150. The easy part is tracing out the rubber hoses and capping off any open ends. With the manifold, remove the EGR valve and put in a bronze cap to block off the EGR hole. You can get almost any fittings you'll need for your manifold at home depot or lowes. The hard part is concerning the exhaust manifolds. Let it be dodge or chevy, there is always some kind of tubes that run from the smog pump to the back or the sides of the exhaust manifolds. And most of the time, the fittings or bolts holding the tubes are rusted to hell and are hard to break.
Its probably gonna take a day or weekend when you can carefully trace out all the hoses and wires. It's a pain in the ass no matter what it is. Most of my info here is based on the stock 80' 305 that was in my malibu so hopefully a 307 is similar. If not, then my bad.
User avatar
all4gss
Postby all4gss on Mon Sep 28, 2009 11:27 pm
pat,
do you know what size plugs are needed to stick in the exhaust manifolds? My 350 has the stock smog equipment and the little air pipes going into the exhaust manifold near each cylinder. I'd like to get all the pieces in order before I start pulling appart the smog equipment. I imagine that would be a loud exhaust leak if I had to drive across town b/c I had the wrong plug.
Did you find the plugs at Lowes/Home Depot?
Thanks,
real POWER comes from above.
el camino... the way... John 14:6...
User avatar
patmckinneyracing
Postby patmckinneyracing on Mon Sep 28, 2009 11:39 pm
If I remember right, all the parts were metric while some were standard. I got the fittings from home depot. I don't know the exact size but what you can do is take one of the fittings with you and match up the threading and size. More than likely the thing is going to be metric. Sorry I can't give an exact measurement cause the last time I took out those small tubes was almost 5 years ago.
User avatar
1985Diablo
Postby 1985Diablo on Tue Sep 29, 2009 4:35 am
It all depends. Heres what I did on my 85. Ordered a duel exhaust kit from Summit, $250 I think, included headers/mufflers/and pipes that exit just in front of the rear wheels. Pulled the entire exhaust from the heads back, removed the AIR pump and all related hoses/valves/tubes/ect. Installed the new parts and done. NOTE, depending on the cross member you have this might not fit on the driver side.
if you keep the stock system keep in mind, in addition to the tubes going to the exhaust, you also have one going to the Cat that must be blocked off .
I have a torch, a grinder, and a 30 pack of beer, Yeah, we can make it fit..
User avatar
patmckinneyracing
Postby patmckinneyracing on Tue Sep 29, 2009 9:36 am
You can use the stock system, but there is so much crap thrown on these motors to the point where it's easier getting rid of all the junk, including the cats, and just finding a cheap set of headers. The way you can do this cheaper is by using the stock exhaust. You can cut off the extra pipe that ran to the manifolds so the pipes will match up with the headers. If you have a MIG welder or know someone who does, they can do this job for you or you can buy exhaust clamps. With the catalytic converters, you can cut those off and just run a piece of connecting exhaust pipe. Most auto parts stores sell these as either solid pipes or flexible pipes that you can cut to size.
Typically you can find a cheap set of headers for roughly 50-80 bucks. This is an alternative in case you decide that the smog system is just too much of hassle. With my old smog system. I ended up chucking the whole 305 because it was filled with so much sludge it was never going to run right.
dan2286
Postby dan2286 on Tue Sep 29, 2009 3:34 pm
The 307 has the tubes running into the heads, not the manifolds.
84 Cutlass
Next
Return to How-To's / Knowledge Base
Who is online
Users browsing this forum: JJLT1, Kevin88ls
