The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
Get the GBodyForum e-mail newsletter!, Contests, Events, Deals, Forum News and More!
GBodyForum Supporting Vendor
TH350 to 2004r/700R4 Overdrive swap
Stuff like brakes, frame, springs/shocks, tranny's, etc. etc.
User avatar
JBreu
Re: TH350 to 2004r/700R4 Overdrive swap
Postby JBreu on Mon Jun 21, 2010 4:49 pm
I just went from a th-400 and went to the 700-r4 and have no regrets at all.........You can use the stock crossmember as lond as you get a tail shaft from a late 80's Caprice, caddy or buick roadmaster 700-r4...... Here is a link to that :http://www.chevyhiperformance.com/techarticles/46278_automatic_transmission_overdrive_install/index.html. YOu will need geometry corrector brackets and a TV cable bracket as well...............Available from Jegs or Summit........Both the 200 and 700 are great tranny's if built right.......I was able to throw 4.10 gears in my car and still cruise the expressways at a low rpm :) As far as the driveshaft.....you will need 49.5" from center of U-Joing to center of U-Joint--that's with a 7.5 rear or 12 bolt.......and take off another inch if your going to the 8.5 rear. Hope this helps...
1984 Monte Carlo with sbc 388 stroker ( dynoed 514hp) 700-r4 , 12 Bolt w/4:10
Old Chevy's Don't Die, They just get faster!
Best ET to date : 12.20 @110 Mph All Motor
User avatar
DrRansom442
Postby DrRansom442 on Wed Jun 23, 2010 9:03 am
wasn't really trying to discourage the use of the 700-r4 .... if one has a "good" 700-r4 just laying around and it's going into a Chevy powerred car (I don't like the concept of adapter plates) - use it. But all things considerred comparing the 2 and considerring swapping into a A/G body car (which never had the 700) - I think the 200-4r has it hands down.
3 time A/G-body owner
86 Cutlass Salon 307/200-4r (salvaged May 04)
87 Cutlass Supreme 307/200-4r (stolen Oct 04)
81 Cutlass Calais 260/350 (purchased Nov 04)
never thought I'd say "I miss the power of a 307"
Calais tranplanted a Olds 350/200-4r
Previous
Return to Chassis / Drivetrain / Suspension / Wheels
Who is online
Users browsing this forum: MeanBuicks
