GBodyForum Supporting Vendor
are all 2004R transmissions the same?
Stuff like brakes, frame, springs/shocks, tranny's, etc. etc.
User avatar
bill
Postby bill on Sun Jan 02, 2011 9:58 pm
Just wondering if there are different versions or years/models of this transmission and what makes one year or model better or worse than the others. Mine is out of a 88 caprice wagon. I have the tag number. anybody got any info on build changes or upgrades from the general throughout the years?
THanks!
GOT TORQUE?
85' Cutlass Salon / Astro Roof / Stock 70 Olds 350 w/Edelbrock Performer Intake (2711) and 650cfm Edelbrock Carb (1406) / 200-4R / 2000 stall GN-Torque Conv. / 3.73 posi w/disc brake conversion / Ceramic Headers w/Pypes Duals.
chevy2480
Re: are all 2004R transmissions the same?
Postby chevy2480 on Sun Jan 02, 2011 10:07 pm
Yes there is different versions. For example the GN 86-87 used a brf valve body some have the Kc valve body some have BQ and so on and so forth. The case is essentialy the same but the internals differ valve bodies govenors etc. The brf is suppost to be the most desired but i not 100% on that.
81 Cutlass Cruiser Wagon; 406 SBC, 12:1 comp, Hbeam rods,forged crank, Comp Solid roller 4/7 swap 673/672 lift, Victor Jr, AFR 220 heads, Comp roller rockers, custom built 945 hp carb,Trans Specialties Th350 Ultra bell and transbrake with ATI 8" 4000 stall, 8.5 10bolt 4.10 gears, moser full lightweight spool,33 spline moser axles, C-Clip elim,moser rear girdle, SSM Suspension, Drag Bag. Roll cage. Best to date 10.93@122.98
86 GN Stock motor,PTE 6262E, 60lb inj.,TT Chip, Mease 3" Dp, Mease modified stretched Duttneck intercooler,Art Carr 9" 3K stall N/L ,Razor Alky,scanmaster,RJC power plate,autometer gauges,casper knock gauge,Adj press reg, k@n, Lt1 maf + translater.Pypes exh, SSM suspension, Drag Bag.Best et to date 12.58@106 leaving on no boost and a trans that slips bad on 2/3 shift.
84 Cutlass Supreme. Traded
User avatar
bill
Postby bill on Sun Jan 02, 2011 10:10 pm
Im thinking this one is a KCF code trans. Im hoping that it has a bit more strength since it was in a Caprice wagon.
Thanks!
GOT TORQUE?
User avatar
bill
Postby bill on Sun Jan 02, 2011 10:47 pm
checked it again....its a KTF code.
I found this article on Hemmings web page.
http://www.hemmings.com/mus/stories/200 ... ture9.html
and also this info.....
Here is a chart of some of the more popular codes:
TH-200-R4 ID's:
ID Year(s) Application
KZF Olds 442/Hurst
CZF 85-88 Monte SS
CRF 85-88 LG4 305 powered Monte Carlos/Pont Gr Prix
BRF 86-87 GN/T-Type/Turbo Regals
BQ 84-85 GN/T-Type/Turbo Regals
BR 83 Model T-Types
TAF 89 Turbo Trans Am
OZ Hurst Olds
OM Olds 350 Diesels
OG lds 307
BY V-6 252 Cars
AA and AP Cadillac's
Unfortuately, I dont see a KTF code here, so I dont know whether its a better one or not... :roll:
GOT TORQUE?
Free Shipping on Orders Over $75!
User avatar
Postby Longroof79 on Mon Jan 03, 2011 11:55 am
Bill,
The 200-4R unit that I have is a CTF code. Apparently from an '89 Chevy Caprice. It will definitely need some upgrades for a performance application. Valve body, governor, servo, etc.
Jack
'79 Malibu wagon, mild 355 sbc, TH350 trans, 8.5 GN rear
Future upgrades: built 200-4R trans and 3.42 gears
Return to Chassis / Drivetrain / Suspension / Wheels
Who is online
Users browsing this forum: Judge Mills, UMI Sales
