For street and strip a 700r4 with 3.73 gears would be the ideal setup IMO. Get a nice shift kit and you'll be having fun in no time! If your not relying on the gears as much as the torque of the engine to get you moving then you could go with 3.42s or even 3.08s (maybe). But keep that overdrive transmission! You will regret it otherwiselaman1982 said:STRIP AND STREET
-83MONTESS- said:For street and strip a 700r4 with 3.73 gears would be the ideal setup IMO. Get a nice shift kit and you'll be having fun in no time! If your not relying on the gears as much as the torque of the engine to get you moving then you could go with 3.42s or even 3.08s (maybe). But keep that overdrive transmission! You will regret it otherwiselaman1982 said:STRIP AND STREET
Look mainly for 85-88 Monte SS's. Thats where I got mine and they are less rare than alot of the other Gbodies that had them.laman1982 said:-83MONTESS- said:For street and strip a 700r4 with 3.73 gears would be the ideal setup IMO. Get a nice shift kit and you'll be having fun in no time! If your not relying on the gears as much as the torque of the engine to get you moving then you could go with 3.42s or even 3.08s (maybe). But keep that overdrive transmission! You will regret it otherwiselaman1982 said:STRIP AND STREET
thanks for the info! but now i need posi with 3.73 gears do you what cars had them ? that would fit right up with my 87 monte carlo ss??
