The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
350 olds build questions..
TeezySupreme
G Body Guru
Re: 350 olds build questions..
Postby TeezySupreme on Sun Jan 22, 2012 4:06 pm
DoubleV wrote:Cheap forged flat top pistons and a set of 8 heads would be a good choice as it would give you about 9:1 CR with good quench ( everything of course would need to be measured to get an exact CR and quench ) which would work well with your cam ( though there are better cams out there ).
Since the #8's big chambers is actually a benfit to you from a CR standpoint, all you'd need to do is hog out some of the excess material on the exhaust side and they'll flow just as good as the earlier heads.
I've never heard anything good about NAPA doing good machine work, so make sure you've got a guy who actually knows what he's doing or just spend a couple bucks more ( maybe ) and go to someone who has a good rep just to be sure.
When I get the heads done do I ask them to port them?? Annd what type of cam would you use??
Olds power but I still love Chevy :-)
User avatar
DoubleV
Postby DoubleV on Mon Jan 23, 2012 7:47 am
The exhaust side on the 8 heads ( just the bowls I think ) is really the only thing that needs to be done for them to flow on par with the better earlier heads. If you know a competent head porter, then he should know how much work to put into them for better performance at the power level/RPM range you'll be driving it at. A good valve job is always a good thing too, but any head porter will know that.
I would talk to Ultradyne/Bullit or Lunati cams for a cam recomendation if you want to get one that'll work the best. It will depend on your exact CR, gears, stall and other things you may not have the answers to yet. That's why it's always best to just pick the cam last. Off the top of my head, I'd recomend the Voodoo 213/219 duration cam which is just one small step above mine and would be great for a 350 with about 9:1 CR where exellent street manners are a must.
85 Olds 442
Botched Olds 350 build by the crooks at Rocket Racing. Lunati 207/213 Voodoo cam, 8.1:1 CR ( was supposed to be 8.8:1 ), Stock #7 heads ( were supposed to have a performance valve job and valves that actually sealed ), American Racing headers, Performer RPM intake, Qjet with 1/2" 4 hole spacer, 2.5" Pypes X-pipe system, cowl induction scoop.
Engine never ran the way it was supposed to from day one due to Rocket Racing's negligence.
Cutty1
Postby Cutty1 on Wed Jan 25, 2012 1:09 am
damn that sucks i bought my motor in in 2010 ad it has the #8 heads... the motor is suppose to be rebuilt to stock.. the block is 68 though ... that kinds bumps me out that these heads are shitty, i hope theres a least a difference from the crappy 307, and yes the motor been sitting on the motor stand since i got it waiting for taxes to pull through so i can throw it in and hopefully be happy with it
1980 Cutlass Calais now with 68 350 rocket. posi with 3.08,ImageImage
TeezySupreme
G Body Guru
Postby TeezySupreme on Thu Jan 26, 2012 5:00 pm
DoubleV wrote:The exhaust side on the 8 heads ( just the bowls I think ) is really the only thing that needs to be done for them to flow on par with the better earlier heads. If you know a competent head porter, then he should know how much work to put into them for better performance at the power level/RPM range you'll be driving it at. A good valve job is always a good thing too, but any head porter will know that.
The cam shaft size you recommended I cant find it where would I be able to find that at?? O my piston are goin tobe 1.612" the block will match it the heads also valve jov all that so what would be the best cam for that o and they are forged..??
TeezySupreme
G Body Guru
Postby TeezySupreme on Thu Jan 26, 2012 10:55 pm
The edlebrock cam I put up of this cam which is better?? http://www.summitracing.com/parts/CCA-CL42-222-4/
User avatar
brettlaage03
G Body Guru
Postby brettlaage03 on Thu Jan 26, 2012 11:35 pm
I have the same block and heads. So I can use flat top pistons and a mild cam, open up the exhaust side of the #8s and still make decent power? I really dont think my budget allows for all the machine work so I will do gaskets rings and bearings as long as everything looks good.
78 Monte Carlo t-top 327/th350 aluminum intake and Demon carb, dual exhaust, needs lots of tlc
92 k1500 ext. cab short box 350/700r4, 04 6.0 vortec waiting to be rebuilt for future swap!
User avatar
olds307 and 403
Postby olds307 and 403 on Fri Jan 27, 2012 12:57 am
Use the number #8 heads with any of the available flat top pistons. You will have mill the heads even with a re ring and gasket. Composite gaskets are thicker than the factory shim gaskets. Even with stock pistons, with thicker gaskets it would have been at 7.8 to 1.
88 Cutlass Supreme Classic, 424 ci SBO stroker build coming soon, 94 chev Z71 4x4, TBI 76 350 Olds, 5A heads,A4,204/214 cam,Sanderson's and duals, rebuilt 4L60E,3.73 gov lock, 2010 Challenger SE, Stone White, leather, 18" wheels, 2000 Dodge Dakota Sport Club Cab 4x4, 3.9 v6 and 3.92 no slip.
User avatar
online170
G Body Guru
Postby online170 on Fri Jan 27, 2012 11:35 am
DONT SPEND ANOTHER CENT UNTIL YOU FIGURE OUT WHAT YOU WANT!
Make power on a budget usually doesnt happen. If you are planning on rering-regasket, figure on $800-$1000 rebuilt as stock. If you want to do any performance upgrades, $1500-2000 by the time youre done for a very mild build. If you want to make power and dont get carried away, $3500-5000. Be honest, what do you want to accomplish here?
ADVICE:
Decide everything before you spend a penny. What youre buying, price, etc then post it here for advise. What youre doing in this thread is great, just dont buy the parts until you have the whole combo worked out. Some of it might change, and money goes out very fast on builds.
BUILD IT FOR TORQUE!, Torque moves you, and you will like it better for a mild build.
1) Throw away your 650cfm carb, dont care what it is, its not enough. You need a 750, i promise it will be better.
2) HEADS HEADS HEADS HEADS HEADS! The power is in the heads. If you can afford to go to $5k, get a set of edelbrock heads, and the highest lift cam with the smallest duration you can find, and throw it on and go. If youre paying someone to port your heads, buy a set of eddy's, its more bang for your buck, and a better investment if you decide to sell later.
3) Compression helps ALOT. Aim for 9.5-1, you can still run pump gas. Can go all the way to 10.5-11:1 if you go with eddy's.
4) Torque converter! If youre running an auto, get a nice converter or you will never realize the power.
5) Gearing, dont go crazy with it, these engines made good torque. 3.08 is very good, 3.42 is perfect, 3.73 if youre brave, but highway isnt nice. These engines like to overheat.
Dont get carried away, because you can probably spend the same money on a 455 and have way more power. If it were me, id rering, regasket with the highest lift shortest duration cam i could find, headers, torque converter, aluminum intake and a 750cfm carb, and call it a day.
-Azeem K.
Ottawa, ON, Canada
User avatar
dogshit
Postby dogshit on Fri Jan 27, 2012 12:58 pm
That was a great post. 3.73s are excellent as long as you have an overdrive transmission. 3 speeds are for 70s cars, race cars, or bare bones compromise builds where you do what you have to with what you got. Have you seen this young mans thread? Motor stuff doesn't really start until about page 9.
viewtopic.php?f=10&t=10154
His Olds 350 build details what he did with heads & cam and includes pics. 10.2-1 compression with factory heads and pump premium. Still a nice driver combination only one that pulls hard. Who the hell wants to go through all the work and expense of building a motor to have an end product thats ordinary and boring? Yes you tamper it with common sense benefiting from those with experience. Which I commend him for as thats what he is here looking for. That said to many cooks make a bad soup. Follow a recepie of a build that accomplishes what you want and that you can make your budget work to even if its in steps.
In the muscle car era if it had a small block it was your moms car. When you turn your car on does she return the favor? Life's short enjoy your ride. Hybrid burns gas & rubber. Check out my photo album.
87 Olds 442, Blue on Metalic Silver with 275/60/15 drag radials on 15x8 442 wheels, 10-1 509ci Cadillac, 800cfm Q-jet, Performer intake, Street ported heads, 230@50 518 lift cam, Headers, Built 200-4R, 2800 stall lock-up converter, Electric fans & in-tank fuel pump, Factory AC, All factory guages work including tach & oil temp with the 509, Functional Hurst hood & rear spoiler, 36mm hollow sway bar, 3.42 posi 8.5, 17.0 mpg hwy, sold :(
87 Buick Grand National, Tuxedo Black w Chrome 275/50 drag radials on 15x8 GN wheels, 231 Buick V6, TE-60 turbo, Stretch intercooler, 42.5lb injectors, 3" downpipe, 3000 stall lock-up converter, Meth/water injection, 3.42 posi 8.5, 22 mpg hwy, original owner ~ Goal for both cars 11.8 ETs / 115 mph in the quarter reliably on pump gas
User avatar
online170
G Body Guru
Postby online170 on Fri Jan 27, 2012 2:05 pm
Bill Trovato know his shit. Theres a youtube video of him building a shortblock for V8TV for a turbo olds motor I beleive. I learned ALOT of info from that video. Its him assembling the motor, highly recommend taking a look.
Good catch on the overdrive, my olds experience is with a 1969 cutlass, so I forget about the overdrive option in G bodies.
-Azeem K.
Ottawa, ON, Canada
User avatar
dogshit
Postby dogshit on Fri Jan 27, 2012 2:20 pm
You know I saw a 70 Buick Gran Sport 455 that was upgraded with a 200-4R at the GS Nationals and thought it was very cool. He even modified his column shift indicator to reflect the OD.
TeezySupreme
G Body Guru
Postby TeezySupreme on Fri Jan 27, 2012 11:23 pm
online170 wrote:DONT SPEND ANOTHER CENT UNTIL YOU FIGURE OUT WHAT YOU WANT!
ADVICE:
I wanna spend around 1500 the things you said you would get you wouldnt change the pistons??
User avatar
online170
G Body Guru
Postby online170 on Sat Jan 28, 2012 1:35 am
At 1500 you can maybe put a cam in and that's it. Plus clean, crack test, hone, rings, gaskets, and bearings. You could save 150 on assy if u wanted.
Pistons don't fit in your budget. Not sure why some ppl saying not to get heads. You could probably score a set for free to 100. Valve job is 300. Porting usually costs around 2k.
Lots of used headers for around 75 but can't comment on fit.
-Azeem K.
Ottawa, ON, Canada
TeezySupreme
G Body Guru
Postby TeezySupreme on Sat Jan 28, 2012 1:47 am
online170 wrote:At 1500 you can maybe put a cam in and that's it. Plus clean, crack test, hone, rings, gaskets, and bearings. You could save 150 on assy if u wanted.
I can get the block done along with the heads for around 300 together and the pistons would be 360 but 2k for porting thanks for telling me that because it's not going to happen..
TeezySupreme
G Body Guru
Postby TeezySupreme on Wed Feb 15, 2012 1:02 pm
Alright, I'm getting aftermarket pistons for my build but I cant find any with the same compression height so I think im going to have to get the deck shave a little right?? and I also wanted to know if i do have to will my edlebrock performer intake fit on it without being stock deck height??
PreviousNext
Return to Oldsmobile Cutlass / 442 / Hurst/Olds
Who is online
Users browsing this forum: No registered users
