The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
white letter tires
User avatar
T.noble24
white letter tires
Postby T.noble24 on Thu Feb 09, 2012 6:54 pm
Who has the cheapest white letter tires. Like a bf goodrich or others? Please help me out fellas
" IT IS WHAT IT IS " ....
83 Cutlass Supreme. 87 Euro Clip, 355 SBC . Eaton posi unit 3.42 gears. 350 turbo tranny.
User avatar
mebe007
Re: white letter tires
Postby mebe007 on Thu Feb 09, 2012 7:01 pm
Firestone Firehawk Indy 500 are a nice tire and there not very expensive.
1980 buick regal
viewtopic.php?f=25&t=2983
350: Bored .60, Kieth-Black flat top Hypereutectics, Edelbrock performer RPM cam, Edelbrock performer RPM intake, Speed demon 650cfm w/vacuum sec, Worked 993 heads, Scorpion roller rockers, Comp Cams double roller timing chain, Aluminum high volume water pump, Mallory HEI, Melling high volume oil pump, built TH350 , Coan Racing manual reverse valve body, and a Hughes 2500 street master torque converter, Hooker longtubes, G-Force cross member, 2.5 true duals w/x
User avatar
Intragration
G Body Guru
Postby Intragration on Thu Feb 09, 2012 7:08 pm
You might find some cheap off-brand or house specialties if you shop around at the chains...not my personal preference or what I would choose, but if you've gotta have tires and don't have the money, I guess it's an option.
Mike - 1983 Oldsmobile 455 Cutlass
My build thread http://www.gbodyforum.com/viewtopic.php?f=10&t=35347&hilit=sleeper+build
User avatar
T.noble24
Postby T.noble24 on Thu Feb 09, 2012 7:25 pm
I'd like to have some decent tires but dnt wanna spend a fortune
User avatar
-83MONTESS-
Postby -83MONTESS- on Thu Feb 09, 2012 7:33 pm
BFGoodrich Radial T/As are about $100 each give or take depending on size. Thats a pretty good price for the quality you get. Tires is an area I wouldnt skimp out on unless it was just to move the car back and forth for bodywork or something like that. You might wanna look at some Douglas tires, they are a very cheap, shitty quality tire but im not sure if they offer white lettering.
1983 Monte Carlo SS - 6.6L 400 SBC, TH400, 3:73 posi.
User avatar
dogshit
Postby dogshit on Thu Feb 09, 2012 8:13 pm
Having had both on the same car the Firestone Firehawks are a better tire look good and get better reviews than the BFG and are usually slightly cheaper. That said BFG makes more sizes and it looks like you have 14" Olds ralleys. If you want a muscle car look you can do the BFGs in a 25.4" tall 205/70/14 up front with a 25.6" tall 245/60/14 in the rear.
http://www.Tirerack.com has an average price of $103.50 per tire. They look bad arse on a black Cutty adds to the attitude. Wider than the ideal on the rear rim but keep the air pressure right and you won't have any problems with wear etc. If you know someone who has a Sam's Club membership you can usually get them there cheaper after you add the shipping price in at Tirerack. Plus you can get them mounted and balanced at Sams club cheap.
Awe man you gotta lose the hood ornament. Its a carryover from grandpas 70s boat.
In the muscle car era if it had a small block it was your moms car. When you turn your car on does she return the favor? Life's short enjoy your ride. Hybrid burns gas & rubber. Check out my photo album.
87 Olds 442, Blue on Metalic Silver with 275/60/15 drag radials on 15x8 442 wheels, 10-1 509ci Cadillac, 800cfm Q-jet, Performer intake, Street ported heads, 230@50 518 lift cam, Headers, Built 200-4R, 2800 stall lock-up converter, Electric fans & in-tank fuel pump, Factory AC, All factory guages work including tach & oil temp with the 509, Functional Hurst hood & rear spoiler, 36mm hollow sway bar, 3.42 posi 8.5, 17.0 mpg hwy, sold :(
87 Buick Grand National, Tuxedo Black w Chrome 275/50 drag radials on 15x8 GN wheels, 231 Buick V6, TE-60 turbo, Stretch intercooler, 42.5lb injectors, 3" downpipe, 3000 stall lock-up converter, Meth/water injection, 3.42 posi 8.5, 22 mpg hwy, original owner ~ Goal for both cars 11.8 ETs / 115 mph in the quarter reliably on pump gas
User avatar
T.noble24
Postby T.noble24 on Thu Feb 09, 2012 8:26 pm
I wanna do some 15" soft 8's. I wanna tire that can hold up to some burn outs and some street pass's. But I can't quite afford drag radials or anything with another kid on the way lol. I know burnt outs will kill any tire tho .
User avatar
Doug213xrj
Postby Doug213xrj on Thu Feb 09, 2012 8:27 pm
Call Discount tire. I have RWL on all my car`s/truck`s. Cooper cobra`s are a good tire.
Doug
User avatar
sh1ft
Postby sh1ft on Thu Feb 09, 2012 8:32 pm
Tire rack probably has the best choices, depending on were you are in the country try checking with Discount tire. I have sold white letters from Bfgoodrich, Cooper, Goodyear, Firestone and Uniroyal. They each have off brands that can be found at most of the local tire stores in your area. I personally have to stick with the Bf, I am brand loyal to Michelin after seeing all the research they do.
User avatar
dogshit
Postby dogshit on Thu Feb 09, 2012 8:43 pm
In that case I would probably run the Firehawks in a 235/60/15 all the way around for the ability to rotate. $101 per tire. Good warranty also 5 year 55,000 free replacement first three years then prorated until 2/32" remaining depth. Naturally obvious burn outs evidence would void that. :mrgreen:
njRegal86
Postby njRegal86 on Thu Feb 09, 2012 9:17 pm
you could try Primewell tires because they are pretty cheap, but also i think made in China your choice. I think 80Z Babiez is running Primewell tires on his car, go with Primewell PS860.
User avatar
trocutlass63
Postby trocutlass63 on Thu Feb 09, 2012 9:37 pm
I've got 225/70R14 BFG Radial T/A's on my Cutlass and they look and perform great. I got them from Discount Tire for $98 per tire a year ago and they usually have good specials and discounts on a pretty regular basis.
'85 Oldsmobile Cutlass Salon-Olds 307, TH350, 7.5" 10 bolt
Mostly stock (for now)
Return to Oldsmobile Cutlass / 442 / Hurst/Olds
Who is online
Users browsing this forum: No registered users
