The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
Get the GBodyForum e-mail newsletter!, Contests, Events, Deals, Forum News and More!
It appears you're not logged in! Not a member? Registration's FREE and only takes a minute!
Register now or Log in to hide this ad block.
GBodyForum Supporting Vendor
Best way to lower my el camino
Stuff like brakes, frame, springs/shocks, tranny's, etc. etc.
Crapple21
G Body Guru
Postby Crapple21 on Fri Feb 03, 2012 3:24 am
Im going for the cheapest way to lower my el camino as me being a college student with not a lot of money. Just wondering what the best and cheapest way to do it. Any help is appreciated thanks
User avatar
jrm81bu
Re: Best way to lower my el camino
Postby jrm81bu on Sat Feb 04, 2012 5:48 pm
Cheapest-Cut them.
Best-Most likely spindles in front and lowering springs in rear.
81 Malibu
400(350 for now) 142 supercharger
700r4
3.73 posi 7.5
User avatar
cdg1984
Postby cdg1984 on Sat Feb 04, 2012 6:18 pm
cutting them will give you a bumpy ride. I highly recommend saving for a bit and getting some drop spindles.
Crapple21
G Body Guru
Postby Crapple21 on Sat Feb 04, 2012 6:22 pm
I have read stuff about using f body springs? And that lowers it some but don't know how much work it is and what not to do that?
hoodfellas1987
n00b
Postby hoodfellas1987 on Wed Feb 15, 2012 12:55 am
I've been researching all that stuff too bc I'm trying to do the same and the spindles in the front are about $200 and the springs for the rear roughly range from $75-175, and my conclusion so far has come to spindles in the front and lowering springs in the rear which is probably the best way to go and i have looked into the s10 springs which will lower it about 2 inches. As for me i think I'm going to go with eibach lowering springs all the way around bc i don't know if i wanna drop the front yet my concern as of know is the rear
Crapple21
G Body Guru
Postby Crapple21 on Wed Feb 15, 2012 2:09 am
What year springs from a s10 can you use and the front or rear? Because I don't necessarily want performance I just want low.
User avatar
drogg1
Postby drogg1 on Wed Feb 15, 2012 2:24 am
Nice El Camino. This page has good info on using fbody springs and s10 springs:
http://jeffd.50megs.com/Moog_Spring_Page.htm
Drop spindles give you a two inch drop and can be had for around 160 dollars + shipping.
http://www.summitracing.com/parts/DJM-DS2031-2/
s10's have the same front suspension as our cars so those will work.
As far as whats best, easiest, etc., I wouldn't cut your springs. Besides that, replacing your front springs requires you remove the wheels, brakes, shocks, and popping loose at least one balljoint on each side in the front to get the springs out. This should be done with caution as the springs will shoot out and could hurt you if you are not careful. For the rear springs, you need to remove the shocks and raise the car while lowering the rearend until the spring is loose. These are not as dangerous and should fall right out.
Here's some articles that might help you out:
http://www.carcraft.com/techarticles/sw ... index.html
http://www.superchevy.com/technical/cha ... index.html
'83 Monte Carlo CL T-Top
383c.i. 13.0:1
Hopefully running E85. PM me if you have any advice on E85 fuel systems or converting a gas Holley or Quadrajet to E85.
Crapple21
G Body Guru
Postby Crapple21 on Wed Feb 15, 2012 2:28 am
Okay thank you those sites have great info!
Return to Chassis / Drivetrain / Suspension / Wheels
Who is online
Users browsing this forum: UMI Sales
