The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
help , dropped rear on GN 3", no travel left
Bags, notches, sparks... the whole deal! (Keep it friendly guys!)
GregInAtl
n00b
Postby GregInAtl on Sun Jul 05, 2009 11:11 am
OK, I have an 86 Buick GN, I have it lowered a bunch, Moog coil 5385s w/ a coil removed, dropped it right at 3". I have KYB shocks, rear disc conversion, and 20x10s on 275-30s.
Here's the deal. It has no travel. Its all tire...and there aint much there!!
The rear driver caliper was hitting the frame, so I notched a vertical slice in it for clearance....test drove it, now its clear but now I have 1" travel.
Anyone w/ a G-body experienced this? I have seen many regal's lower than this, and something just doesnt add up. The shocks surely have more than 3" of travel...
Shed some light if you can...
Greg
86 GN, 20"s, 3" drop and go fast stuff
07 Passat Wagon 2" drop and 20"s
01 Frontier 4" drop and 18" Escalades
User avatar
dogshit
Postby dogshit on Sun Jul 05, 2009 1:00 pm
You are where you are. With that much drop they are more for shows. Harsh ride no travel and no traction under boost. I lowered mine an 1 1/2" with the Eibach springs and run a 275/50. Its a lot firmer but not harsh still has sufficient travel and has enough side wall to hook. I could not stand the idea of spining and getting whipped by a slower car with traction. But you will definately get more props at some shows.
In the muscle car era if it had a small block it was your moms car. When you turn your car on does she return the favor? Life's short enjoy your ride. Hybrid burns gas & rubber. Check out my photo album.
87 Olds 442, Blue on Metalic Silver with 275/60/15 drag radials on 15x8 442 wheels, 10-1 509ci Cadillac, 800cfm Q-jet, Performer intake, Street ported heads, 230@50 518 lift cam, Headers, Built 200-4R, 2800 stall lock-up converter, Electric fans & in-tank fuel pump, Factory AC, All factory guages work including tach & oil temp with the 509, Functional Hurst hood & rear spoiler, 36mm hollow sway bar, 3.42 posi 8.5, 17.0 mpg hwy, sold :(
87 Buick Grand National, Tuxedo Black w Chrome 275/50 drag radials on 15x8 GN wheels, 231 Buick V6, TE-60 turbo, Stretch intercooler, 42.5lb injectors, 3" downpipe, 3000 stall lock-up converter, Meth/water injection, 3.42 posi 8.5, 22 mpg hwy, original owner ~ Goal for both cars 11.8 ETs / 115 mph in the quarter reliably on pump gas
GregInAtl
n00b
Postby GregInAtl on Sun Jul 05, 2009 8:23 pm
I know there are G bodies that low w/ travel. The height isn't a problem if there is some travel, the spring rate and tire choice will be the issue then. With no travel I could be on drag radials and have problems. Its just not very low to see, it doesnt look slammed, it seems bizarre that the travel is so limited. I took a long look today, and nothing is in contact (frams to anything, bump stops to anything, and lower arms dont appear to be touching anything either.
Greg
AnPmc
Postby AnPmc on Sun Jul 05, 2009 10:50 pm
It's real nice, I don't see how Your Car is giving You Trouble, Doesn't Seem that Low at all.
User avatar
custom442
Re: help , dropped rear on GN 3", no travel left
Postby custom442 on Mon Jul 06, 2009 12:04 am
GregInAtl wrote:OK, I have an 86 Buick GN, I have it lowered a bunch, Moog coil 5385s w/ a coil removed, dropped it right at 3".
those springs have a free load of 167 lb/in which is very stiff even at stock height or 1" lower than stock. Basically you got one of the stiffest springs possible and now is stiffer after the coil was cut.
You don't see many rear coils close to 200 lb/in on street driven 4 link rears without coilovers -- because you can't adjust them like coilovers
You can have decent traction at that height, but your geometry has completely changed, time to look into adjustable control arms
86 cutlass supreme 383, 31% finished
06 silverado 262 ci s/c, 12psi and broke head unit
GregInAtl
n00b
Postby GregInAtl on Mon Jul 06, 2009 3:15 pm
We are all talking rear susp right?!?!
What spring could I use to get some ride back and have some travel? I plan on removing spring and shock and dropping the car down, just to see when it begins to bind.....shouldnt that be at bump stop compression?I was considering QA1 coilovers rear only. My frontis fine, I have Moogs up there w/ 2" drop spindles, and its a little stiffer than I want, but it keeps the tires off the liners.
Thx for the help guys, keep the suggestions coming, I certainly do not know it all! (Obviously)
Greg
User avatar
custom442
Postby custom442 on Mon Jul 06, 2009 6:29 pm
GregInAtl wrote:We are all talking rear susp right?!?!
yes, rear suspension. (200 lb/in front coils are way softer than anything ever used on these cars)
And you might never reach the point where the bump stops come into play with those springs installed because it's so stiff to begin with.
Rear springs are very particular, we've been through a few threads on here about the rear pigtails and it's hard to find a correct spring for a swap, although it can be done. Cutting pigtails isn't the best idea either. IMO I would look into a drop spring at the height you want. Like QA1 or eibach just as examples (front springs you can do fine with moogs). They might be about twice what you'd pay for a MOOG that's supposed to drop the rear--like using an Abody or monza spring on a g body, but it's worth knowing what the specs are on the spring and that you'll have a driveable ride.
I would buy drop springs and fully adjustable rear shocks. If you really want to convert to coilover you could, but it's so expensive and not needed unless you have a specific need for perfect geometry (race car).
GregInAtl
n00b
Postby GregInAtl on Mon Jul 06, 2009 9:36 pm
200lb are softer? They feel WAY firmer....I am used to 375 and 400 lb springs in import cars and them riding 1000x better than this big heavy car on 200 lbers.
what am I missing? I want a comfortable ride, not OEM soft (tiny wire used on the coils) but not a wagon either.
Greg
User avatar
jrm81bu
Postby jrm81bu on Mon Jul 06, 2009 10:43 pm
He was saying that 200 lb/in would be too soft for a front spring.
But as a rear spring thats pretty stiff.
81 Malibu
400(350 for now) 142 supercharger
700r4
3.73 posi 7.5
User avatar
custom442
Postby custom442 on Mon Jul 06, 2009 11:12 pm
Greginatl- here's some info to help explain a little better
Stock these cars had around 300-350 lb/in in front. In rear, about 100-130. A stock rear susp. set up on these cars will perform best with around a 1.5" drop, which is about the max you can go without changing out other rear susp. components.
So you could see how a 200 lb/in at a much lowered ride height would cause problems. When you drop the car 3"s you're losing just about any suspension travel. The max you really should go with a coil spring set up on these cars with stock geometry is about 1.5-(maybe) 2" in.
In a simple way - a 200 lb/in spring at a 1" drop is now 400 lb/in, at 2 inches it's 600 lb/in, at 3" it's now 800lb/in This isn't saying your rate is 800lb/in at all, but spring rate is just a representation of the real world calculation of wheel rate. You can't really tell the wheel rate without linkage ratios, weights, etc.
But it's not the end of the world - here's what to do for better results (you could even try it with your current springs). Set a correct/decent pinion angle with new adjustable upper arms (adj. lower arms wouldn't hurt either). Also remove the rear frame rail bump stops but keep the stop on the pinion
Look at this chart: http://bbb-carb.com/moog_Coil_Springs.htm
note your 5385's have a free height of 12.6". At that free height they have a spring rate of 167.5 lb/in.
But on whatever stock vehicle they came on, it lowered it to a 9" ride height. The original 167.5 lb/in was then multiplied by 3.6" (free height - install height) to get the 603 lb/in at install height.
When you cut a coil (depending on the spring) it usually increases the spring rate beyond the amount of lowered height you just cut off ... if that makes sense.
Also when pigtails are cut, it screws up rates/performance and can have mounting issues, just take a look at a pigtail spring and you can see what I mean by that.
GregInAtl
n00b
Postby GregInAtl on Tue Jul 07, 2009 1:52 pm
WOW....you are the man 442!
OK, I like the height it is at, it really isnt that low looking....so I wanna stay this height.
So you think my best option is a predropped spring 2"+ if anyone makes one, (this was suposed to be 1.975" drop from OEM...but actually raised my car) or second option is maybe a coil spring w/ a near oem rate so when a coil is removed it will make the rate closer to an aftermarket rate and be dropped down?!!
I like everyone am on a budget, and when my moogs installed were 1" higher than my OEM 1986 coils I couldnt have it.....the ziz wheel had to come out.
I am contemplating using my OEM sagged spring w/ a coil removed (softer rate than my moogs obv) and w/ the new shocks maybe I'll be near where I am now w/ control and a more reasonable rate.
Am I following you? I know cutting a pig tailed coil isnt a great solution, but 3" drop on a G body rear seems to be like shading the sun w/ a magnifying glass.
Greg
User avatar
custom442
Postby custom442 on Tue Jul 07, 2009 5:43 pm
This is just stuff I've picked up from books and here on the forum.
I would try to find a drop spring for around a 2" or more. It could be hard to find, but it's worth getting a decent spring rate. And if you must cut a coil, yes make sure it's a softer one than you started this time with. I think most of these cars came with around 115 lb/in springs. You could also call moog and should be able to get the specs on a few different springs that came stock on your car. It's not really recommended to cut over 1 coil but people have done it
You can also google to find spring rate/wheel rate calculators that will help if you'd like to try another moog spring.
I'm wondering about this one, where did you get that info from?
User avatar
jrm81bu
Postby jrm81bu on Tue Jul 07, 2009 5:56 pm
81 Malibu
700r4
3.73 posi 7.5
GregInAtl
n00b
Postby GregInAtl on Tue Jul 07, 2009 9:16 pm
TurboBuick.com had a big Moog thread where people w/ OEM cars measured before and after certain spring installs.
I found my issue tonight when I removed the coils and let the car down.....rear calipers barely hit frame still. I will have to notch teh frame up a few inches at that point to clear them.
Friggin rear disc conversion!
Greg
User avatar
custom442
Postby custom442 on Wed Jul 08, 2009 12:33 am
good to hear you found the problem! make sure to look into those upper a arms.
Next
Return to Customs / Lowriders
Who is online
Users browsing this forum: No registered users
