The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
How To Swap Buick V6 3.8 to SBC 350
Articles about swapping engines and anything related, mounts, exhaust considerations etc.
User avatar
dougfather
Moderator
Postby dougfather on Tue Sep 11, 2007 8:27 pm
This is a "How To" Post to swap the following engine in a G-Body:
To: Small Block Chevy V8 (305, 350, 400, and others)
Disclaimer:
Parts and "How To" are listed in each section. I consider this a continous working and living post. This is by no means a final revision and other topics related to engine swaps will be added. While topics as rear end ratios and transmission are somewhat related, specific details of those topics are beyond the scope of this post and deserve their own unique topic.
Feel free to reply or send a private message in regards to the specific engine swap mentioned. There is more that needs added and if you have specific knowledge, feel free to share.
Suspension:
The Front Coil Springs need replaced with ones used in any V8 G-Body. This assumes you won't be taking out any weight (such as A/C- Heat removal, installation of fiberglass/aluminum body panels, etc) Ones from a Monte Carlo SS are a little stiffer than other V8 G-Bodies.
While you're at it: If you still have the original suspension bushings, ball joints, tie rods, etc, now is a great time to replace all this stuff. Since you already need to change the front springs AND with the engine out, it is much easier to do this work. Also makes it easier to change out the motor mounts.
Mounts:
You will need the proper G-Body Specific Chevy V6/V8 Mounts. When properly installed for a V8, one of the motor mount holes will hang off the frame. Only 3 of the 4 holes on the motor mount are used.
Passenger side engine cradle, viewed from front, with and without the mount installed. Motor mount holes are marked. The top holes on the mount are spaced 2-5/16" centers and the bottom hole are 1-3/4" centers (only one bottom hole is used).
While you're at it: If you bought motor mounts form a junkyard and have the old rubber bushings, drill open the old mounts and replace with new Energy Suspension (or your favorite equivalent) polyurethane inserts. Chances are the 20+ year old rubber is well worn. Instructions are included with the new bushings
Transmission and Cross-Member:
Most V6 cars got a THM200C (3 speed). These make a great door stop or practice for learning to rebuild a tranny (like I did). It most likely won't withstand any power from a V8. Besides, it has the wrong bolt pattern. You will need a specific SBC bolt pattern OR a dual bolt pattern transmission. A THM350 (3 spd) with Chevy Bolt Pattern will work with the THM200C cross-member.
If using the THM200-4R (4-Speed overdrive), you will need the specific cross-member. Any G-Body built before 1984 will need a mounting point for the TH200-4R cross-member added to the frame by welding in a piece of steel. It will not bolt in otherwise.
Along with rear differential, the transmission you chose depends on budget and goals and therefore further discussion goes beyond the scope of an engine swap.
Electrical:
ALL G-bodies have a wire harness that mounts to a bulkhead on the driver's side, right under the wiper motor. This does NOT include the ECM wire harness on 81 and later gas powered G-bodies. The harness has 2 pieces. The left half (viewed from the front of the car) is for the engine. The right half (which can be pried out, carefully) is for lighting and horns. The picture below shows the ENGINE harness with the lighting/horn harness removed. The black plastic wire loom is removed for clarity.
LEGEND:
PURPLE - Starter Solenoid (has a ring terminal at the end)
PINK - Distributor (most likely a slip on terminal)
RED (2) - Starter at the battery terminal. Have larger ring terminals with fuse link. Has a splice for the HVAC system.
GREEN - Temperature sending unit
BROWN - Alternator sending unit
The following three work together in one circuit and depends on weather you have guages or idiot lights
LT BLUE - Choke heater
LT BROWN - Oil Pressure Light
BROWN/WHITE Oil Pressure Light
Fuel Line:
You will need to swap the fuel line so that it routes to the passenger side. Given the car's age, now would be the time to run new fuel line from the tank to the engine. If keeping the emissions controls, you will need at least 2 lines, one for the fuel and the other for the charcoal canister. If using a fuel pump with a return OR if you decide on fuel injection, a third line will be needed for a return.
Cooling:
You will also need the radiator, fan shroud, fan, hoses for a V8 G-body. The radiator for a V6 will not be sufficient.
Also the proper water pump is needed for the Chevy V8. Be sure to use the proper water pump for the belt drive system you decide to use (serpentine or v-belts). The 2 work in opposite directions.
Revs
REV A - 09/11/2007 - First Release
REV A1 - 09/12/2007 - Text font and color changes
REV B - 9/14/2007 - Combined Transmission and Cross-member. Added notes about pre-84 frame for TH2004R. Added Fuel Line and Cooling sections.
Giving Credit where due:
85 Cutlass Brougham - info on pre-84 frame for transmission cross-member and fuel lines.
User avatar
dougfather
Moderator
Postby dougfather on Tue Jun 03, 2008 2:15 pm
FAQ
All questions have been deleted and added here.
Q: Were can i find i good set of motor mounts? I have a chevy 350. Also,
where would is a good place to find the block mounts (steels not the clamshells) be? The junkyards around me do not have any older cars in them.
A: Check our sponsors, local auto parts stores, or a junkyard. Whichever mounts you need, make sure to order it for a Chevy powered G-Body (83-87 Pontiac or 78-87 Chevy, with a 305 gas V8 ). As for the inserts, Energy Suspension makes the polyurethane inserts. Any Chevy powered G-body will have what you need.
Q: this thread is great! just wondering what differences there are with the 350 sbo mounts? thanks!
A: Way different, not even close.
Q: So if i have a/c on a 3.8 engine will it all bolt up or do i need to convert everything to the sbc a/c system?
A: None of the 3.8 V6 a/c parts will bolt up, you'll need all the appropriate SBC bracketry. (answer by Blake442)
A: just the bracket dont need a diffrent compressor or lines (answer by Johnny MV1).
A: Doug's Comment - you may need different AC lines since the compressor is in a different location.
Q: Found this article most informative. It answered a lot of questions I had. however exhaust was not mentioned. Do I look for headers specific to the body style, 78 Lemans Safari in my case, or will any G body system of the correct year work??
A: Any G-body SBC header will work, though some brands fit better than others. I got mine from DynoMax and am very pleased with the fit and quality. As far as the rest of the exhaust, a standard G-body kit won't fit the wagon, as there are differences with the tailpipes necessary to clear the fuel tank. (answer by Blake 442)
84 Pontiac GP - Chevy 350 and THM200-4R. Finally in. More to come
07 Ford Fusion - 2.3L w/ automatic and gets 30mpg highway
04 Chevy Colordao Z71 LS Crew Cab with one of those fangled 5 cylinder engines
81 Olds Cultass 4dr - 231 V6 3spd auto (R.I.P)
User avatar
CALI-WAGON_09
transmission mount & cross member question
Postby CALI-WAGON_09 on Thu Feb 19, 2009 3:22 am
i have a 79 malibu wagon i am at the last stages of a engine swap from a buick 3.8/t200 trans to a chevy small block 350/t350 trans i want to know can i use the same cross member and mount or what do i have to do because my original mount is offset to the side of the trans andmy cross member is not lining up its off about a quarter of an inch any help is appreciated
User avatar
jrm81bu
Postby jrm81bu on Thu Feb 19, 2009 7:44 pm
Assuming you put the new small block mounts in the correct holes, you should be able to use the stock crossmember and mount.
81 Malibu
400(350 for now) 142 supercharger
700r4
3.73 posi 7.5
User avatar
CALI-WAGON_09
Postby CALI-WAGON_09 on Thu Mar 05, 2009 3:11 am
I PLACED THE MOTOR MOUNTS IN THE SAME LOCATIONS THAT YOU DID IN YOUR PIC ITS ALMOST LINED UP SO I THINK IM GOING TO TRY AND SHIFT THE TRANS OVER A LITTLE BIT WITH THE ENGINE CONNECTED TO THE CHERRY PICKER(RELIEVE SOME ENGINE WEIGHT) I HOPE IT WORKS THANKS FOR THE ADVISE!!!! ALSO DO YOU HAVE ANY PICTURES OF THE WIRING CONNECTIONS ON THE ENGINE
eighty3gresr
n00b
Postby eighty3gresr on Thu Jun 11, 2009 6:15 pm
the tranny isn't offset just the cross-member. You should get a new transmission mount because it has a bracket that offsets the mount to the side.
User avatar
chromemoly4130
Postby chromemoly4130 on Fri Aug 07, 2009 10:12 pm
Here is a picture of the Moroso 62630 solid frame pad for 1974-81 Camaro/Firebird mounted on a 86 Monte Carlo ss
as you have stated
dougfather wrote:You will need the proper G-Body Specific Chevy V6/V8 Mounts. When properly installed for a V8, one of the motor mount holes will hang off the frame. Only 3 of the 4 holes on the motor mount are used.(only one bottom hole is used).
and if this is true,comparing the pictures
I would say that they will work on the Regal as well....... now for the solid motor mount,you will need to get the Moroso 42515 thats for these frame pads. sorry for the pic. size but I thought I would pass this info along.
4130 :twisted:
User avatar
dougfather
Moderator
Postby dougfather on Tue Aug 11, 2009 11:00 am
just deleted a few posts and combined them in the FAQ above.
User avatar
pjpj1979
Re: How To Swap Buick V6 3.8 to SBC 350
Postby pjpj1979 on Mon Sep 21, 2009 2:35 pm
Quick question...If I'm going from a 2004r to 700r how much shorter on my drive shaft to I need go? Just an estimate.
thanks!
'87 Cutlass Supreme Brougham - 350sbc /Edelbrock Performer Intake/Holley 600 cfm/ HEI MSD/Accel Ignition/BBK Aluminum Underdrive Pulleys/Hedman Headers/Magnaflow x-pipe & mufflers/TH350 - (still in progress)
User avatar
81CRUISERbrougham
Postby 81CRUISERbrougham on Fri Jun 11, 2010 2:15 pm
i was thinking doing a sbc with th350 over the winter while im not driving my wagon. it had a 260 th200m now a 3.8 th350.. when installing the mounts will new holes need to be drilled for the mounts and from what i gathered if i use th350 chevy it will work on the oldsth350 crossmember? how much of the olds wiring will work on the sbc. just FYI ive never put in a chevy motor in anything. i had a 78-79 ford pick up and bronco addiction before my newfound Gwagon lots of 400m and 429's.
1981 Cutlass cruiser brougham 3.8
2004 alero 3.4
2006 silverado 2500
User avatar
jcbannis
Postby jcbannis on Mon Dec 27, 2010 11:14 pm
81CRUISERbrougham wrote:i was thinking doing a sbc with th350 over the winter while im not driving my wagon. it had a 260 th200m now a 3.8 th350.. when installing the mounts will new holes need to be drilled for the mounts and from what i gathered if i use th350 chevy it will work on the oldsth350 crossmember? how much of the olds wiring will work on the sbc. just FYI ive never put in a chevy motor in anything. i had a 78-79 ford pick up and bronco addiction before my newfound Gwagon lots of 400m and 429's.
the holes should be pre drilled and a th350 old is all the same as a th350 chevy just different bellhousing pattern and the wiring should work also but the dist. maybe be different if your going with a hei
lets get this right your honda has 1.9 litres and my pepsi has 2
84 monte ss 385 stroker built 350 turbo work in progress
User avatar
1985cutlasssupreme
G Body Guru
Postby 1985cutlasssupreme on Mon Sep 26, 2011 3:20 am
would a THM200-4R fit on a regular 231 v6?
maliburacinfreak
Postby maliburacinfreak on Mon Sep 26, 2011 7:06 am
1985cutlasssupreme wrote:would a THM200-4R fit on a regular 231 v6?
yes
80 MALIBU 2DR PROJECT
81 CUTLASS
71k mile grandma ride
lookin' MUCH better with wheels and tint
User avatar
1985cutlasssupreme
G Body Guru
Postby 1985cutlasssupreme on Mon Sep 26, 2011 4:12 pm
yes
cool thanks for the help man.
Member # 77
Postby Member # 77 on Wed Oct 19, 2011 9:05 am
V6 to LS1
Next
Return to Engine / Swaps etc.
Who is online
Users browsing this forum: Evan's 85
