The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
Speedometer error and related issues !
Keep it clean! :)
User avatar
87BlazeLS
Location: Apopka Florida "burning out near a twist in the road "
Postby 87BlazeLS on Sun Sep 09, 2012 8:56 am
I know about the speedometer calibrator section in the faqs. But, I do not know what my current gears are.
I figured since many of you guys probably have done the same swap I did it has been figured out already....
OK so I had a 305 / 200R4 combo with 2.41 rear gears 205/70 R/ 14
Now I have a 350 / TH350 combo with same 2.41 rear gears and 255/ 60 R /15 27" tall
OK some back ground - The transmission was out of an 85 Chevy pickup just for reference..
When driving the car the error is around 25 MPH on the slow side. (reading 25 mph at 45 to 50 actual)...
I need to know what drive gear color and driven gear color to get it in the correct ball park.
Suggestions anyone ?
NEXT, Due to the swap of said transmissions above my shift indicator (column shift LS ) is mounted in the speedometer
housing. However the red needle is stuck at Park. And does not move.... I no longer need the P-R-N-OD-2-1 from the
200R4 transmission. I need to replace it with the P-R-N-D-2-1 common with the 3 speed automatic.
Can I get just the replacement indicator and swap it out ? Or does this require a different speedometer all together?
Any help with this issue would be super... Thanks in advance jake 87BlazeLS
RestoRides MotorSports " We make custom look so good "
87 LS 350/290 H.P GM performance Crate motor, TH 350 trans, 2200 stall B&M TQ convertor, 600cfm Summit Street /strip carb, EB Performer RPM intake , GM performance HEI, Jegs headers, Thrush turbo mufflers, Flow master 2.5" pipes, Custom Blue LED int. lighting, Gabriel High jacker air shocks, 3rd motor , 124 K miles , 12 Custom bullet marker lamps, 1959 Cadillac Aux. brake lights, smoothed front fenders, 1992 dodge stealth hood bulges, custom hand made grill, dagger column shifter, Forever sharp wood /billet steering wheel, Chrome/wood door pulls, bug eye fog lights, more to come....
stuckincincy
Re: Speedometer error and related issues !
Postby stuckincincy on Sun Sep 09, 2012 10:14 am
this page will tell you what drive and driven gears are available. TH350 is about 1/3 of the way down.
http://www.transmissioncenter.net/speed ... ____va.htm
Then you can go here to calculate which gears you need.
http://www.bgsoflex.com/speedo1.html
As for the gear position indicator, you didn't indicate what kind of car. Most of the overdrives are just an overlay. If you remove the bezel there should be two screws at the bottom of the indicator. If you remove those you should be able to remove the OD plate the standard three speed markings should be underneath.
User avatar
87BlazeLS
Postby 87BlazeLS on Sun Sep 09, 2012 11:33 am
Thanks for the links. MY stage name here should have been a give away for the type car I have, As in 87 monte carlo LS
It has been rebadged with Blazer emblems with the "R " cut off And a Flame in chrome.
As I stated I do not know what gears are inside the speedometer connection at the TH 350. Can these be pulled out easily ?
Fluid loss ???? I know the speedometer cable can be unscrewed from the case easy enough.
I've never done a speedo re gear... Sorry for numbness....
And how do I fix the broken red needle movement ???? A wire ? A spring ?
jake 87BlazeLS
stuckincincy
Postby stuckincincy on Mon Sep 10, 2012 1:01 pm
The driven gear is fairly easy to replace. Just remove the cable and then the retaining bolt and you should be able to pull out the sleeve and driven gear as a unit. (you will lose a little fluid) Gears are color coded so when you pull out the unit just look up the color and that will tell you how many teeth you have. To find the number of teeth on the drive gear just look inside the hole where the driven gear assembly was to find the color. It's easiest to try to find the correct driven gear for your setup, but depending on final gear and tire size you may have to change both gears. If you have to change the drive gear you need to remove the tail shaft housing to get at the gear.
There are two possibilities for you gear indicator depending on if you have a column or floor shift. If you have a column shifter, the gearshift needle is attached to the steering column behind the bezel by a small cable a U-clip. You can usually reach it by removing the trim piece below the column and reaching up from the bottom. Just pull the cable until it indicates what gear you are in and push it back onto the column. I like to put it in neutral or drive since that is about in the middle.
If you are using a floor shifter and the linkage from the trans to the column has been removed you will need to replace the linkage to get it to work. Either way the needle attaches to the column the same way.
User avatar
87BlazeLS
Postby 87BlazeLS on Mon Sep 10, 2012 9:15 pm
Hey thanks for the extra effort, I guess that means there is a point of no return on selection.
Meaning unless the drive gear fits within the driven gears range you need to pull the tail shaft.
This requires removal of transmission ... I wont go there for the sake of speedometer Error.
I may look at alternate methods of correcting the speed.
If another less expensive alternate exist I would go there. Trans was just pulled for a B&M torque
converter swap 9/02/2012 $400
87BlazeLS jake
User avatar
455'ed80Regal
Postby 455'ed80Regal on Mon Sep 10, 2012 10:49 pm
No need to pull the trans again. Just drop the driveshaft and pull the extension housing off the trans. To get your speedo close you will need a 10T drive gear and 18T driven gear. Swapping the gears out is pretty straightforward after you get the extension housing off. Fluid loss will be little to none if you raise the rear of the car to change to gears out.
Robert
2nd owner of 1980 Regal w/118xxx, 3.8L, T350, 2.41 gears, factory buckets, floor shift, center console and gage package.
User avatar
dogshit
Postby dogshit on Mon Sep 10, 2012 11:36 pm
He asked specific questions and got good specific answers. Great. But he still seems a bit green with building what sounds like a performance street car. So here is my thoughts or questions; if performance is the objective the 2.41s need to go. Assuming you want to get the most out of your gear swap (such as the best quartermile gear for the power he has) and that gas isn't free out there and that he wants to protect or get the most out of his engine investment ie rebuilds & parts are not free either.
Why not rebuild if it needs it or add a shift kit etc if not to his 200-4R? Especially since he already has it. Maybe it FUBAR but nobody likes going backward and he made no mention of this being a drag or roundy round car. Just thinking we should ask as many newbs to building hot driver.project cars way under estimate the value of an OD vs an older non OD trans. Anyway so say a 4.10 gear would get him a lot better acceleration than a 2.74 (same final drive ratio) and still get the same or better mileage as well the same or less engine wear. He may also not know the benefits of a lock up converter especially for a well cammed motor or than the trans weighs less and has less parasitic loss. Some people know that a lock up converter saves gas but don't realize it also especially on a higher stall keeps a lot of heat out of the cooling system. Maybe he has thought of this or not or maybe as mentioned the 200-4R is FUBAR and he is just trying to get it up and usable as quick and cheap as possible for now. Anyway food for thought.
In the muscle car era if it had a small block it was your moms car. When you turn your car on does she return the favor? Life's short enjoy your ride. Hybrid burns gas & rubber. Check out my photo album.
87 Olds 442, Blue on Metalic Silver with 275/60/15 drag radials on 15x8 442 wheels, 10-1 509ci Cadillac, 800cfm Q-jet, Performer intake, Street ported heads, 230@50 518 lift cam, Headers, Built 200-4R, 2800 stall lock-up converter, Electric fans & in-tank fuel pump, Factory AC, All factory guages work including tach & oil temp with the 509, Functional Hurst hood & rear spoiler, 36mm hollow sway bar, 3.42 posi 8.5, 17.0 mpg hwy, sold :(
87 Buick Grand National, Tuxedo Black w Chrome 275/50 drag radials on 15x8 GN wheels, 231 Buick V6, TE-60 turbo, Stretch intercooler, 42.5lb injectors, 3" downpipe, 3000 stall lock-up converter, Meth/water injection, 3.42 posi 8.5, 22 mpg hwy, original owner ~ Goal for both cars 11.8 ETs / 115 mph in the quarter reliably on pump gas
User avatar
84clonewars
Postby 84clonewars on Tue Sep 11, 2012 1:13 am
Like Vern I'd also consider using the 200-4R trans it will bolt right up to the sbc.
Antoine
84 Hurst Olds T-Tops - Puchased 11/13/11 - Olds 403 .020 over - #5 Heads - Comp XE262H Cam - Comp Roller Tip Rockers - Heddman Headers - Edelbrock Rpm Intake - 200-4R - 8.5" 3:73 Posi Rear -THE BRUISER
83 Buick Regal - Purchased 4/7/12 - 72 Buick 355 - TH350 - Digi Gauges - 7.5" Open 2:29 Rear - THE CRUISER
84 Chevy Camaro - Purchased 1/4/10 - T-Tops - Chevy 355 - 700R-4 - Posi 9 Bolt BW 3:42 Rear - 2000 Camaro Interior - Work In Progress - THE ABUSER
84 Buick Regal Limited - 75 Olds 350 - 350 BOP Trans - KILLED BY FAMILY MEMBER 8/10/11
User avatar
87BlazeLS
Postby 87BlazeLS on Tue Sep 11, 2012 7:00 pm
Had a 200R4 now have a TH 350. This is a Ratrod project car. I know full well the 2.41 gears need to go.
This was not the question. It was correcting speedo error. Yes I'm green on this car but have been building hot rods
for years just not with a TH 350 and a chevy v8. The TH 350 is perfect. Gone thru and good to go. Just not with
the speedo gear in mind.
Since there is considerable error I thought I would ask what you think. I'm here to get info. I have the ability to do
damn near anything. Just though a little extra from the ones who know would be better than blindly attacking something
that I have not dealt with before.
jake
User avatar
87BlazeLS
Postby 87BlazeLS on Tue Sep 11, 2012 8:10 pm
On second thought I did not consider the fact that it is possible the speedo gears need to be selected
AFTER the rear gear ratio is changed out.... No doubt 2.41 is not where I want to be.
I think it would be best to concentrate on the gear swap in the 10 bolt first and then re-gear the speedometer.
I would like to get gears around 3.23 to 3.40
I'll be shopping for these parts in the next few weeks.
thanks for all the comments.
jake
User avatar
dogshit
Postby dogshit on Wed Sep 12, 2012 10:22 am
Rat rods are cool & fun. 8) I think you are on the right track. I did not know the scope of the project and its more obvious now that you are very accomplished. But wow who has built cars for years & never messed with a sbc & a th350? Well maybe I'm getting older.. my boys haven't & their grown & graduated. :shock: :oops: :) When she comes together post us up some pics with an update.
User avatar
87BlazeLS
Postby 87BlazeLS on Wed Sep 12, 2012 9:40 pm
In time my friend in time. The project car is one that I personally wanted to do for the Chevy 100 year anniversary .
The engine was purchased dirty and spent. It is from a 79 Camaro 2 bolt main. I never had the chance to build a true hotrod.
I've dealt mostly with Ford trucks, Chevy trucks, Mazda Miata's, Geo Metro, Mercury Montego, Even VW beatles.
The monte has had it's time with being stock. It was the perfect Rat Rod project car. Not too far gone to fix up but yet not
too perfect either. Not looking for a concourse car here. Not into judges with Microscopes looking for fine line scratches in the paint. Here is a run down on the mods this car has. And please understand that every dollar of this build has been funded from the sale of Teflon Window guide kits for Mazda Miata's.
355 cu in Small block, 0.030" over, Stock crank, Rods, Keith black Pistons, Melling HV pump, Roller tip rockers, H.P coated push rods, New Lifters, Comp Cams mild street grind cam, Edelbrock RPM Performer intake, Edelbrock 600 CFM carb, Blue printed HEI distributor, Shorty headers, Dbl roller timing chain, New Valves, seals, Springs, 3 angle valve job, new water pump, new radiator, new Trans oil cooler, Modified drive shaft, Rebuilt TH 350 trans, New wheels and tires ($1500) , New Carpet, New door sills, All new gages, New rear tail lights, Additional 59 Caddy Tail lights, Bullet LED marker lamps, LED turn signals, 92 Dodge stealth hood bulges, 2.5" high riser hood scoop with cowl induction, all new brakes rotors, drums, New Patriot Sidepipes, New Seat belts, New U joints, All belts and hoses are new, All rubber weather strip is new. Freshly painted
Satin Black by me in drive way.
I know the car is not perfect but a lot of time and effort mostly done by me went into this car to make it very special.
No others look like this one. I have about $2500 in the car minus the Labor. About a year since the tow truck delivered
it bone stock to the driveway. So far I've driven it about 20 miles. Still working out all the little details.
Looking forward to giving some advice and getting some in return...
jake 87BlazeLS
Return to General Discussion
Who is online
Users browsing this forum: No registered users
