Ok new at this forum thing so here i go.
So i had the red single wire off the alternator disconnected to free up room while i had the valve covers off. when i went to put the wire back on, it touched the side of the alternator and it sparked... now when i turn the key, nothing happens. no clicks no starter. what did i fry?
- this is an 81 elcamino , no ecm. carbed 350.
- also the buzzer comes on when i put the key in the ignition but no instrument cluster power. interior lights still come on.
i believe i traced the wire all the way back to the firewall where it goes to the fuse block
- all fuses visually look ok.
could this be a fusible link?
thank you all in advance!
