GBodyForum Supporting Vendor
front weight reduction
oldsrcr
n00b
Postby oldsrcr on Tue Jan 20, 2009 6:12 pm
Does any body know the weight of the front bumper on a '79 with the aluminum inner and also the steel core support, trying to decide if a custom core support and glass bumper is in the near future. There's not alot of lightweight parts for this car that I've found so far and I already have a fiberglass hood. I really dont want to put a factory aluminum support in if Im tearing it apart anyways to get the steel one out, I would probably just build a custom one. Thanks
User avatar
dudeface
G Body Guru
Postby dudeface on Tue Jan 20, 2009 11:31 pm
if ya wanna lighten the bumpers..........easiest way is simply chop it up. if ya look at the bumper and core support ya really only need a small part of the core to bolt the bumper on. pretty sure you could chop away at least 60 to 70 % off it and still look stock. as for strength well its probably pretty weak that way. but super light
peace
User avatar
Blake442
Postby Blake442 on Wed Jan 21, 2009 2:44 am
I know you have a '79, but this may help anyways...
81-88 Cutlass Factory Component Weights:
--------------------------Aluminum-----Steel
Hood----------------------22.5 lbs-----53 lbs
Rad. Core Support------12 lbs--------24 lbs
Intake Manifold----------17 lbs--------58 lbs
Brake Drums-------------9.5 lbs------12 lbs
Front Bumper Core------8 lbs---------25 lbs
Rear Bumper Core------11 lbs--------35 lbs
You'll probably be better off buying a pre-fabbed lightweight radiator support or making one yourself...
Finding a factory piece is a pain, unless you're Lue. And they're expensive, because the people that do find them know what they're worth.
'85 Oldsmobile 442--Olds 455-TH400
'83 Oldsmobile Cutlass Cruiser--Chevy 350-TH350
Past G's--'81 Regal, '84 El Camino, '79 Cutlass Supreme, '87 Cutlass Salon,
'81 Monte Carlo, '81 El Camino, '79 Malibu Wagon, '81 Century Estate Wagon
shotgun
Postby shotgun on Wed Jan 21, 2009 9:44 am
Don't have any numbers to help but I did the following to my Cutlass.
Fiberglass bumpers (front& rear), custom aluminum bumper brackets, Aluminum core support, Aluminum radiator,fiberglass cowl hood.
Some weight was added Pontiac 440, th400, 12 bolt and rollbar.
The car ended up 3250# race weight, 225# of that is me.
I also used an Iceman trans crossmember 8#, awesome piece.
He also sell a core/radiator support. In the future I might swap the aluminum one onto my wagon and add his.
http://www.maliburacing.com/iceman
78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z Best to date 10.00@130.92 mph at 3250#
79 Grand Prix, will be new home for the 440 Goal "street Legal" 9.75z@135mph at 2900#
83 Malibu Wagon Crate 350, Custom T5, 8.5 with Auburn posi 3.73z Making it the Ultimate Utility VehicleGo, tow and show (not so much show, yet)
shotgun
Postby shotgun on Wed Jan 21, 2009 10:05 am
Forgot, I saw an ad for a aluminum hood also. They are supposed to be lighter then fiberglass. It is pricey also.
I would not use the aluminum one if you plan on a scoop of any kind, why ruin a neat factory part?
Here is a link:
http://www.maliburacing.com/forum/viewt ... 10&t=78019
User avatar
bigdan
G Body Guru
Postby bigdan on Wed Jan 21, 2009 11:57 am
shotgun ,
have you verified the weight difference between your fab hood and the original steel one ?
Dan
ProPerformance: engine rebuild & mods at honest reasonnable prices ....
1984 cutlass supreme :
350 LT1 2nd gen :
comp cam roller :CC503 / 1.6 roller rockers
gmpp intake / modded Q-jet,
competition prepped 700R4 / 3200 9.5" stall T/C
ford 9" diff with 3:25, 3:55, 3:89, 4:10 gear choice ....
camaro 1LE front brakes
11" rear disc brakes
KYB gas-a-just schocks
bell tech coil springs lowered 1.5"
tubular front A arms
ajustable links rear suspension
gbodyaddict
Re: front weight reduction
Postby gbodyaddict on Wed Jan 21, 2009 1:44 pm
oldsrcr wrote:Does any body know the weight of the front bumper on a '79 with the aluminum inner and also the steel core support, trying to decide if a custom core support and glass bumper is in the near future. There's not alot of lightweight parts for this car that I've found so far and I already have a fiberglass hood. I really dont want to put a factory aluminum support in if Im tearing it apart anyways to get the steel one out, I would probably just build a custom one. Thanks
i save this in my list from maliburacing forum.http://spreadsheets.google.com/pub?key=pw4RXuqpgZP2zw_QcQHvESA&gid=2
oldsrcr
n00b
Postby oldsrcr on Wed Jan 21, 2009 5:24 pm
Thanks for the replies. Does anyone know if the iceman core support fit cutlass also. He has them listed for a malibu and also wondering about price? To my knowledge any two headlight core for g-bodies are all pretty much the same.
shotgun
Postby shotgun on Wed Jan 21, 2009 5:36 pm
Bigdan, No. I never weighed the stocker or glass. I could unbolt the glass one if you really need to know. It's kinda beat up and in black primer so I don't have to worry about scratches.
gbodyaddict, THAT"S MY SPREADSHEET. :lol: Good to see it is being put to good use. I do need to update it abit.
oldsrcr, my understaning it will bolt in. With any install, things like headlight buckets etc may need you to do some minor fab.
Send me one of his, $150 bucks and a return shipping label and you can have my aluminum one. :wink:
Free Shipping on Orders Over $75!
gbodyaddict
Postby gbodyaddict on Wed Jan 21, 2009 6:53 pm
shotgun wrote:Bigdan, No. I never weighed the stocker or glass. I could unbolt the glass one if you really need to know. It's kinda beat up and in black primer so I don't have to worry about scratches.
oldsrcr, my understaning it will bolt in. With any install, thing like headbuckets etc may need you to do some minor fab.
Holy shiiit....sorry man, i should remember where i got it from...Its been useful in other forums too and its very much appreciated.
Next
Return to Oldsmobile Cutlass / 442 / Hurst/Olds
Who is online
Users browsing this forum: No registered users
