The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
stock gear ratio
Stuff like brakes, frame, springs/shocks, tranny's, etc. etc.
Cutty1
stock gear ratio
Postby Cutty1 on Thu Feb 12, 2009 9:44 pm
what gears did the 307 come with originally... cause i know i have 2.14 cause it had the V6 before the 307
SBCregal
G Body Guru
Postby SBCregal on Thu Feb 12, 2009 9:57 pm
the cars came with a few different ratios, best bet it to check out rpo codes
User avatar
85 Cutlass Brougham
Moderator
Postby 85 Cutlass Brougham on Thu Feb 12, 2009 10:20 pm
most V6's had a 2.41 but some had a 3.23. Diesels have the 2.14 as well as some unfortunate gas V8's.
BTW, as the SEARCH! Gestapo here, I will tell you that common RPO codes are listed in the How To section, including gear ratios. I should know because I put it there.
1985 Cutlass Supreme Brougham (ex pizza delivery beater with 240,000 miles):
355 Chevy- 9.5:1 compression, Comp XE 262 cam, World S/R Torquer heads with 2.02's, Edelbrock Performer, 800CFM Q jet, Camaro ram air system,Edelbrock headers, Comp Magnum roller tip rockers,TH 200 4R, 3.23 rear, aluminum hood, IROC steering box, poly bushings, Eibach springs, etc. Cutlass build thread here: viewtopic.php?t=4982
Also: The Thing That Won't Die-1998 Nissan Frontier, 340,000 miles of pizza delivery.
Cutty1
another ? about gears
Postby Cutty1 on Fri Feb 13, 2009 12:18 pm
if i were to switch from 2.14 or 3.23 i have TH350 and non computer controlled, so how does the tranny 's shift points change from the different gears
User avatar
Blake442
Postby Blake442 on Fri Feb 13, 2009 8:54 pm
Your shift points will remain the same.
The only part you'll need to change in your tranny is the speedometer gear.
'85 Oldsmobile 442--Olds 455-TH400
'83 Oldsmobile Cutlass Cruiser--Chevy 350-TH350
Past G's--'81 Regal, '84 El Camino, '79 Cutlass Supreme, '87 Cutlass Salon,
'81 Monte Carlo, '81 El Camino, '79 Malibu Wagon, '81 Century Estate Wagon
Return to Chassis / Drivetrain / Suspension / Wheels
Who is online
Users browsing this forum: FirstClass 383
